Results 1 to 19 of 19
    Junior Member Hogsters's Avatar
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    idling and rpm problem
    Just recently my ls1 started idling differently with the rpms fluctuating up and down. Everything was fine last time I had started it so Im not sure what happened. I've replaced the plugs and the inline fuel filter... there was no change after replacing either one. At some point it just dies out, but I can easily start it back up. Anybody have an idea what might be going on? I not to familiar with these motors and it sits im my 98 Tj. Came out of a 1998 Firebird.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Could be a number of things. A vacuum leak could be the culprit. I would start by checking the intake tube between the airbox and throttle body as that could be loose/cracked, check your idle air control valve(IAC) as those become dirty over time. Also check and clean your mass airflow sensor between the airbox and intake tube as they become dirty. Clean that with some CRC MAF cleaner. Could also be an EGR issue as those tend to crack over time. If you need anything else, give a shout.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Any codes?
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    Thanks for the feedback! I'll be trying these one by one and step by step along with a few youtube video's on "how to". Hopefully I can find a diagram to show me the location of the parts somewhere online.
    I tried running my OBD11 but not able to bring up any codes, I'm guessing because it was an engine swap to the jeep tj, I really don't know.
    I'll post back with results hopefully this week.
    I am just going to guess a vacuum leak somewhere...like a hole or crack in one of the vacuum lines. That's the #1 cause of rev's jumping around. Cammed goat's recommendations are also good ones. Let us know what you find.
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    I'll start there seems to be the cheapest solution, and I can hear air hissing under the hood but im not sure if it's good air I'm hearing, sounds like the back side of the block on passenger side against the firewell.
    I will keep updated as I move along till problem is solved.
    There are a couple of things it could be.
    If you still have it in stock configuration the EGR tube that comes from the drivers side valve cover (rear) around to the same location on the passenger valve cover then runs along the passenger side of the intake that connects to the pcv. This setup almost always causes vacuum leaks.
    2nd cause back there could be the MAP sensor is crack, loose. Also since this is a engine swap into another vehicle I would look at the intake as well if you don't find an obvious leak.
    When you can post up some pics. Interested in seeing a TJ with a LS1 in it.
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    Ok I took the throttle body off today and cleaned it up. Unscrewed the two little connectors on it and spayed some of that cleaner on them, (Im not sure what they call the connectors). I checked for cracks but couldn't find any.... it still not right. I thought Id take it to the shop but Its going to be a while before I can do that. Should I take a picture of the engine tomorrow and post it here. With the new infor for the EGR I might be able to do more, and I don't know what the IAC looks like. Is it possible that cleaning them wont work but a new one will? Looks like most of the parts mentioned here are all around $25-$35.... I can afford to do that now but cant afford the labor a shop is going to charge me.
    - - - Updated - - -
    Ok Will Do, and thanks for the feedback!
    North Jersey
    2004 GTO M6
    The IAC is located on the driver side of the throttle body and is held in with two torx-head screws. It is chrome with a black plastic connector. Once you unplug/remove the IAC, check for build up of soot on the pintle and inspect the hole where it goes into the throttle body as the soot cakes up in there too. Use throttle body cleaner and a rag for both and get back to us with what you find.
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    Boy was I wrong about the part prices. So I replaced the MAF with no results. I've ordered the IAC and will put the results up on Friday after I receive it.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Nice looking jeep. I would try to diagnose it more before just wasting money by throwing parts at it. That will get expensive quickly and might not result in any improvement.
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    Well I at a loss....my IAC part came in today, I installed with no results....actually rpms were higher. Don't know what next, but I cant keep replacing parts at their prices.
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    You can take some carburetor cleaner and spray it along all your vacuum lines while the engine is running. If you spray across a leaking/cracked hose, the idle will go down. That is the cheapest and easiest way to eliminate all the vacuum hoses for leaks. Trying to fix a problem by just buying stuff, is NOT the way to find your problem. When spraying said carb cleaner, be careful not to spray to much cleaner on some of the plastic connectors. So try to avoid spraying any plastic. Just keep a rag handy and wipe it off asap. Some plastic is extremely sensitive to the carb spray and will get eaten up by it. The plastic will look like you took a lighter to it.
    1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    Ok so one last go around today and I find a little valve thingy that looks like it should have a hose connected to it but I cant find one, so I think maybe just maybe it suppose to have a rubber cap on it. (It's located on the back of the block in between firewall) So I find a rubber cap put it on and Wala! it runs great again!!! thanks to all those that chimed in, I 61 years old and still learning
    What is the name of that thing anyways, what is it called and do?
    [IMG][/IMG]
    yeah you need that. It's suppose to go to your brake booster or at least on a f body.
    Not sure how yours is setup.
    MARYLAND
    BLACK
    1998 PONTIAC TA
    That is your map sensor. (Manifold Absolute Pressure) The part # is on it. (16212460) On an F-body LS1, is it located on the back of the intake manifold, next to the firewall as you have explained. It should be plugged into the manifold with the tab that you have capped off with the rubber plug. It is possible that whoever did your install just bypassed that, or it came lose from your intake. I know on an f-body, that lil booger is a PITA to get to. If it is unplugged though, as you have found out, it will cause a major vacuum leak and make the engine run like crap. Awesome looking build by the way. That looks bada$$.
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Correction. I now realize you probably referring to the black plastic stem that the MAP sensor is connected to. Yes, as SMWS6TA stated, that stem usually has a rubber hose that goes over to the brake booster, to provide power brake assist. If you look at your brake master cylinder, there is a round black case that should have a hose coming off of it, that is IF you have power brakes.
    Dec 2015
    California
    Blk/Blu
    1998 TJ
    So much knowledge here! I'm assuming since I have hydraulic steering and a brake booster as well, is the reason I'm not using the vacuum hose, and that's why it's capped off. Thanks for all the help with trouble shooting and detailed explanations. Thank You!!
    North Jersey
    2004 GTO M6
    Glad to see you fixed the issue.
  1. Idling
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 07-22-2010, 02:15 AM
  2. A kill while idling?
    By IH8EVRY1 in forum Kill Stories
    Last Post: 05-11-2010, 04:19 AM
  3. Idling RPM's?
    By qwk01ta in forum General Help
    Last Post: 04-27-2010, 10:09 PM
  4. problem idling
    By grouch0jr in forum General Help
    Last Post: 12-18-2009, 07:04 AM
  5. Idling at 650 to 750 RPM's
    By 9t8z28 in forum External Engine
    Last Post: 10-31-2006, 06:25 AM
