Thread: Idling RPM's?
04-27-2010, 06:44 PM #1
Idling RPM's?
I've got a 228r at 112lsa. Got a pretty good lope at idle. Are engines supposed to idle at a particular RPM or is it variable. I think at idle i am at about 900ish. Is it possible to drop the idle RPM's a bit to get a better lope? Any pros or cons to having a particular RPM at idle?
04-27-2010, 07:15 PM #2
I have the 228r on a 114 and I have mine set to idle at 750 or 775. You can drop the idle but the tune gets a little trickier down there....as long as they have your idle airflow tables right you should be fine.
04-27-2010, 07:55 PM #3
by dropping the idle will it have to be retuned from scratch again or will it just be minimal changes via laptop? Just had it tuned a week ago but now realize i would like it to idle a bit lower.
04-27-2010, 10:09 PM #4
should just be minor airflow adjustments but it will most likely need to be changed some.
idling and rpm problem
By Hogsters in forum General HelpReplies: 18Last Post: 12-13-2015, 09:57 AM -
Idling
By edrvsqz1980 in forum Firebird / WS6Replies: 27Last Post: 07-22-2010, 02:15 AM -
A kill while idling?
By IH8EVRY1 in forum Kill StoriesReplies: 18Last Post: 05-11-2010, 04:19 AM -
problem idling
By grouch0jr in forum General HelpReplies: 14Last Post: 12-18-2009, 07:04 AM -
Idling at 650 to 750 RPM's
By 9t8z28 in forum External EngineReplies: 4Last Post: 10-31-2006, 06:25 AM
