Results 1 to 15 of 15
Thread: problem idling
    Philly, PA
    2001 Firebird TransAm WS6
    problem idling
    so this morning i started my car, and it died immediately. confused, i tried it again, and gave it a little gas to hold the rpm at around 1000 rmp, and checked all my gauges. everything looked fine (except for the SES light, which ive had for a while, i need an 'crank re-learn procedure' done. im going to check my codes at lunch to see if anything else was thrown). i let off the throttle again, and the engine just died. no funny noises or anything. i did the same thing one more time, except i held the throttle a little long, and it finally idled around 500 rpm.
    as the car warmed up it acted more normal. this morning was cold, but not the coldest of the year yet. another thing i noticed was that at idle there seemed t be more fumes (no cats) than usual.
    does this indicate a problem with the 02 sensors?
    Philly, PA
    somebody, anybody?
    NC
    SOM
    1998 T.A.
    Dirty IAC is where I would start but get that code pulled......
    Philly, PA
    what the hell is IAC? during lunch it started up just fine. this time it idled a little high. i didnt get the codes read because i have a reader at home, gonna do it then.
    Philly, PA
    ahhhh, idle air control. where is this located?
    when is the last time you changed yoru fuel filter???
    Philly, PA
    never.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    IAC
    Pink Arrow - IAC
    Red Arrow - Throttle postion sensor
    Member luvmyz28's Avatar
    Feb 2007
    Council Bluffs IA
    nbm
    99 z28
    could be a slight vacumme leak as well. my exploder acted like that when it was cold outside. it turned out to be the intake manifold gasket. when it was cold out the gasket would leak. when the engine warmed up the material expanded and sealed it up.
    Philly, PA
    Quote Originally Posted by SOMbitch View Post
    IAC
    Pink Arrow - IAC
    ill check the codes when i get home, then move forward with the trouble shooting.
    NC
    SOM
    1998 T.A.
    There is a little motor in the IAC and sometimes the carbon builds up and makes it stick. If this is your problem a good cleaning will fix it. I have never seen one actually go bad so they usually just get dirty.
    Philly, PA
    how do you clean it?
    Philly, PA
    ok, no codes thrown. so does the eliminate the IAC?
    Florida
    1999 TA WS.6
    No, my IAC was all jacked up and never set a code.
    NC
    SOM
    1998 T.A.
    Unplug it first. Then take the two torx screws out and the valve comes out in one piece.
    Simply spray the hell out of it, everywhere, with MAF cleaner or Sea Foam spray or WD-40.
    Then spray inside the port where it goes. Black crap builds up in there and that black rubber piece on the valve leaves a gummy residue in there. You can twist a rag and stick it in there too to get the crud.
    Also pull it out real slow to make sure the spring doesn't pull out.
  1. idling and rpm problem
    By Hogsters in forum General Help
    Last Post: 12-13-2015, 09:57 AM
  2. Idling
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 07-22-2010, 02:15 AM
  3. A kill while idling?
    By IH8EVRY1 in forum Kill Stories
    Last Post: 05-11-2010, 04:19 AM
  4. Idling RPM's?
    By qwk01ta in forum General Help
    Last Post: 04-27-2010, 10:09 PM
  5. Idling at 650 to 750 RPM's
    By 9t8z28 in forum External Engine
    Last Post: 10-31-2006, 06:25 AM
