    Woodbridge, VA
    Navy Blue Metalic
    1999 Z28 Convertible
    Need help identifying where a 'shimmy' is coming from
    I have a 99' Z28 convertible with the SLP Level II suspension and 17' SS wheels. I am getting a shimmy from the front that I am having a hard time identifying the source. I had the tires balanced/rotated yesterday and it did not fix the problem. Outer tie rods look good, and the inner tie rods we recently replaced with the rack and pinion.
    I am getting a 'shimmy' from the front end at higher speeds, usually noticeable starting around 50 mph. I know the sway bar end links (front and rear) need to be replaced, but could they cause a shimmy? Also, it may be my imagination, but the severity of the shimmy seems to be vary - sometimes the wheel is shaking worse than others.
    The car has been sitting for about 9 months and I just started driving it again.
    What are the 'usual suspects' when trouble shooting a front end problem
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Does it seem like side to side? Or up and down. Your tires might have a flat stop by sitting so long.
    Check the lugs.....it wouldn't be the first time they didn't get tighten properly..
    Woodbridge, VA
    Navy Blue Metalic
    Quote Originally Posted by Ed Blown Vert View Post
    It's hard to tell - If I had to pick I'd say side to side. The weird thing is it isn't a consistent shimmy. Sometimes it is worse than others, and over 70 mph it goes away completely. it's mainly between 50-70 mph. Could worn front bearings cause a shimmy?
  1. Question: Need Help identifying hose/valve coming off throttle body
    By kodiak120 in forum General Help
    Last Post: 04-11-2013, 09:01 AM
  2. shimmy in the front
    By redrocketws6 in forum Firebird / WS6
    Last Post: 06-14-2011, 10:40 AM
  3. good old shimmy at the steering wheel
    By knoll5150 in forum Suspension and Handling
    Last Post: 09-24-2008, 06:23 PM
  4. GTO Steering Wheel Shimmy
    By BRMike in forum Suspension and Handling
    Last Post: 09-09-2007, 03:40 PM
