    Junior Member redrocketws6's Avatar
    Sep 2010
    Ohio
    2000 Trans Am WS6
    shimmy in the front
    Okay this might be a little difficult to explain so here it goes..
    When i drive my car and make a turn at low speeds the front end seems to walk a little bit. or if I am driving, say 35 mph, i will rock the steering wheel back and forth, and after i stop doing that the front end still seems to rock a little bit. It makes me a little weary, as it should. I have already lost one wheel while driving when i had my pos cavalier.
    A guy I work with says it might be the struts getting bad.. im thinking it could be a tie rod. the car had about 90k on it.
    Any ideas?
    Pittsburgh
    2008 Hummer H3
    Check sway bar end links are not broken, check that the mounts/bushings are intact and the sway is'nt broken..
    Could be ball joints or tierod ends too.. Broke both my front end links before..
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Like smittro said, sway or ball joints is where I think it might be coming from.
    To check the ball joints, jack the car up carefully and securely. Then put your right hand on the top of the front tire and push towards the motor while using your left hand on the bottom of the tire pulling toward you. Make a "rocking" motion to see if there's any play. Even a 1/4inch means your ball joints need replacing. Once again, make surethe car is safely jacked up.
    Sep 2010
    Ohio
    2000 Trans Am WS6
    Yeah, I am a mechanic by trade, ive checked the ball joints and tie rods before, they all seemed tight. checked the sway bar bushing when i did the oil change, no cracks. A guy i work here with that has the same car said it might be my struts or strut mounts. Could that be? I know if I go over a bump i here a clumk sound on the right side and when im driving it kinda sways back and forth.(thats why I checked the sway bar first.) and also when I hit the brakes, sometimes to wheel will cut to the right somewhat hastilly. I think I will just have to put it back up and go over it with a fine tooth comb again. its kinda scary, i dont want to lose a wheel on this car too!
    Sep 2010
    Ohio
    2000 Trans Am WS6
    found the problem, it is my control arm bushings on the passenger side worn out.
    Member Ant71130's Avatar
    Aug 2010
    Lebanon, OH
    2002 M6 WS6
    Glad you found it. Tire gone sideways happened to my girl's mother's ranger once. Scary shit. Could only be so many things though, ball joint, CA, tie rod, sway, or those shock/struts. Next time if it ever happens just check the entire area for weakness before driving again. Happens on the highway and... Cya
    Sep 2010
    Ohio
    2000 Trans Am WS6
    Quote Originally Posted by Ant71130 View Post
    yeah it was deffinately the tie rods and c/a bushings. Everytime I would hit a bump i would hear a clunk on the pass side. and while driving the car tends to rock back and forth. So now she is getting all new inner/outter tie rods, poly c/a, sway bar and end link bushings. That should tighten her up. the ball joints were still good and the wheel bearing might be starting to go. we'll fix that the next time around.
  1. Need help identifying where a 'shimmy' is coming from
    By Neil in forum Suspension and Handling
    Last Post: 04-21-2015, 10:54 AM
  2. 2002 Camaro SS Passenger side front fender and front bumper
    By Vexzer in forum Parts Wanted / Trade
    Last Post: 08-21-2012, 06:56 AM
  3. Wanted: Front Fender Front Bumper Headlight Cover
    By ERICALL56 in forum Parts Wanted / Trade
    Last Post: 07-14-2012, 02:52 PM
  4. good old shimmy at the steering wheel
    By knoll5150 in forum Suspension and Handling
    Last Post: 09-24-2008, 06:23 PM
  5. GTO Steering Wheel Shimmy
    By BRMike in forum Suspension and Handling
    Last Post: 09-09-2007, 03:40 PM
