Results 1 to 3 of 3
    Austin, TX
    pewter
    Need Help identifying hose/valve coming off throttle body
    I had a leak previously and taped up this valve/hose. I've done searches and diagram inspections online and I can't find the name of this part or part #.
    Any help is greatly appreciated.
    Thanks!
    It's the pcv check valve. Very common part failure.
    You have a few options on how to fix it.
    This is the most common fix, simple and cheap. But it will also fail in time. Has to do with the design and placement of the pcv
    http://www.ls1.com/forums/f6/pcv-val...ication-80151/
    Here's a more permanent solution but it's a little bit of work.
    Read this first, explains the difference between OEM PCV vs LS6 VCT mod
    http://www.ls1.com/forums/f6/explain...ct-mod-156010/
    Here's how to do the LS6 VCT mod (If you decided to do this rear all of the thread first, ask questions, there is a step that if not done carefully it will ruin you day)
    http://www.ls1.com/forums/f63/ls6-va...r-pics-145557/
    Any questions just ask, I've done both. To be honest I favor the LS6 VCT over the pcv fix.
    Austin, TX
    pewter
    Thanks for the information. I will take a look at both methods an see which one works for me.
  1. Need help identifying where a 'shimmy' is coming from
    By Neil in forum Suspension and Handling
    Last Post: 04-21-2015, 10:54 AM
  2. Hose from radiator to throttle body
    By Matto4785 in forum General Help
    Last Post: 05-27-2013, 05:26 PM
  3. Question: hose that pcv valve goes in
    By Speedy_Gonzales in forum External Engine
    Last Post: 10-04-2009, 07:00 PM
  4. LT1 WS6 Hose that connects from throttle body to the maf sensor/airbox
    By onefastbird! in forum Parts Wanted / Trade
    Last Post: 03-26-2007, 01:56 PM
  5. Throttle Body boost Hose?
    By pxtx in forum Forced Induction
    Last Post: 02-16-2007, 10:19 AM
