    Georgia
    2014 Camaro 1LS
    hose that pcv valve goes in
    I replaced the pcv but it still throws the code.......the hose stays collapased when engine is running........should it ?
    Nov 2008
    harrisburg pa.
    02 vette vert
    no. hose is probably soft and should be replaced.
    Member 1SSWFO's Avatar
    RIGHT BESIDE THE LEMON TREE IN HELL!!!
    LIGHT PEWTER METALIC
    1999 SS CAMARO
    mine done the same shit replaced it with air compressor hose no more issues?
    finally 551 RWHP!!!!
    Georgia
    2014 Camaro 1LS
    thanks......I will replace the hose
    Georgia
    2014 Camaro 1LS
    I replaced the hose and it was ok for a day. Then it threw the code again. Hummmmmm........
    Junior Member D.Grado's Avatar
    Oct 2009
    United States
    http://tierussianwoman.w-
    D.Grado
    well the setup seems to be working. Im just wondering if the pcv hose I cut was designed to be that hard. The one i installed is soft like the others. Just wondering if the gas vapors that go through it will eat away at the hose?
  1. Diverter Valve HOSE cut, Where to buy a replacment!!
    By ryhendricks1 in forum General Help
    Last Post: 03-12-2014, 03:06 PM
  2. Question: Need Help identifying hose/valve coming off throttle body
    By kodiak120 in forum General Help
    Last Post: 04-11-2013, 09:01 AM
  3. JEGS stud mount valve spr. compresor vs. Speeds valve spring
    By JehalinTA in forum Internal Engine
    Last Post: 05-30-2011, 05:16 AM
  4. D-Port Head Valve Upgrade - Big-Valve Performance on a Small
    Last Post: 04-20-2011, 04:10 PM
  5. Air Check Valve and Hose
    By Roxboro Burnout in forum General Help
    Last Post: 04-16-2006, 04:02 PM
