    Hawaii
    Light Pewter Metallic
    1999 Z28
    Power locks intermittently clicking on and off
    Having a weird experience lately while driving on the freeway I can hear what sounds like my power locks going on/off intermittently. Seems more noticeable when driving over rough roads. Has anyone experienced this?
    Are the locks actually moving? Could be a bad connection or a BCM on the fritz.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    I have not had experience with this but one of the first things I would check are the connections to the locks to ensure they are seated correctly and not corroded. You could try cleaning the connections up if dirty. Next I would check out the body control module to ensure it is work properly and it is not surging causing the issue you described if it is indeed the power locks you hear.
    Others may have had this issue and hopefully will chime in.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Agree on the BCM.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Agree on the BCM.
    Another vote for a faulty BCM, the BCM is located behind the glove box.
    You can purchase them on ebay, however they have to be programed to your VIN (I do not know how this is done), or else you will have to change your ignition keys.
  1. Help: Power locks not working. 2000 T/A
    By M1K3H00D in forum Stereo and Electronics
    Last Post: 12-29-2014, 04:13 AM
  2. Power door locks deciding not to work
    By 98ls1t/a in forum General Help
    Last Post: 02-22-2010, 06:23 PM
  3. Help: Power Door Locks
    By jdnoyes in forum Stereo and Electronics
    Last Post: 11-18-2008, 02:27 PM
  4. Getting rid of the power windows and locks....
    By xinthenight in forum General Help
    Last Post: 08-25-2007, 11:18 AM
  5. Power Locks not working
    By firemedic0135 in forum General Help
    Last Post: 06-03-2007, 10:17 PM
