    Junior Member M1K3H00D's Avatar
    Aug 2010
    Fort Hood, TX
    2000 Pontiac Trans Am
    Power locks not working. 2000 T/A
    So my power locks have been out sometime now. One day they up and quit working. Ive seen a wiring diagram, and if i remember correctly it went straight from the lock switches to the BCM and nothing in between. Its been over a year since i was playing with it last because i was deployed, and after just didnt have the time. Now im trying to track down the cause. I remember pulling the bcm and trying to reheat some solder points, but no fix. I can hear it trigger under the dash when i press the lock switches or the key fobs but no movement from either side. Need a fresh idea. Any relays or something else it could be, common in Fbodies? Anything i can check? (Besides fuses...1st thing i checked)
    There is probably a relay in there somewhere as well and that may be what you are hearing. Some pinpoint tests for voltage and ground would be a good first step, however, the BCM is always a prime suspect.
    Aug 2010
    Fort Hood, TX
    Thats what i want to say too. Been a minute since i looked at the wire diagram but i remember tracking both lock switches to the BCM and the bcm to the fuse box and then to the battery...i think. im scared to drop the money on a bcm only to be disappointed. Just want to expend all other possible causes before i jump to the most expensive one haha
    Bump this thread some time tonight as a reminder and I'll also take a look at my books.
  1. Power locks intermittently clicking on and off
    By LavaRock in forum General Help
    Last Post: 04-01-2014, 05:35 AM
  2. Help: Power Door Locks
    By jdnoyes in forum Stereo and Electronics
    Last Post: 11-18-2008, 01:27 PM
  3. Getting rid of the power windows and locks....
    By xinthenight in forum General Help
    Last Post: 08-25-2007, 10:18 AM
  4. Power Locks not working
    By firemedic0135 in forum General Help
    Last Post: 06-03-2007, 09:17 PM
  5. Replies: 9
    Last Post: 03-12-2006, 02:03 PM
