Thread: ZERO Oil Pressure
07-09-2013, 04:33 PM #1
ZERO Oil Pressure
Well according to the dash gauge. It has pressure as engine idles and sounds normal.
I pulled my intake to reseal it for the third time and was pretty sure I did not break the OPSU.
It is not leaking any oil. Is it possible to break the OPSU so it does not leak but can not send correct pressure information?
I can just about touch the thing with my big hands so looks like another manifold pull is in my future.
Jon
07-09-2013, 04:53 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
07-09-2013, 05:18 PM #3
Is the sender plugged in?
07-09-2013, 05:56 PM #4
it is possible to crack the plastic base of the sensor and when the internals move the whole plastic piece moves with it so it will give you a bad reading and it will not leak either. I will double check the OPSU again.
07-09-2013, 08:15 PM #5
yep....when I broke mine it showed zero pressure but no oil leakage.
07-22-2013, 08:21 AM #6
Replaced to OPSU while changing the manifold and oil pressure back to normal.
I left the socket on the OPSU while installing the manifold, seems like it would be harder to break with the steel condom on it.
Help: oil pressure
By Z28boy2000 in forum General HelpReplies: 16Last Post: 07-14-2009, 07:32 AM -
Help: Oil pressure goes down!??
By 98T/A.SNAKEATER_ in forum General HelpReplies: 15Last Post: 11-02-2008, 06:08 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
