Results 1 to 16 of 16
Thread: Oil pressure goes down!??
10-28-2008, 05:38 PM #1
When i put the gas to the floor and giddy up my oil pressure gauge drops to almost and somtimes zero but when i drive normal its just fine. My oil level is right and the car only has 70,000 miles. Wut could this be
10-28-2008, 06:03 PM #2
Considering you know vehicles, hopefully you have checked your oil lately and made sure it's the right level! I could also be old oil, when was the last time it was changed! I'm thinking you have low/old oil or a very dirty oil filter. If all of that checks out fine then I wouldn't be worried about it, hell it could maybe an bad factory oil gauge!!
10-28-2008, 06:06 PM #3
or a bad oil sending unit perhaps??
10-28-2008, 06:20 PM #4
Does your oil pressure light come on when you turn on the car or when your getting into it!? I mean there are just so many thing that can happen like worn main bearings, worn rod bearings, oil pump failure, oil pump screen clogged. Just so many things! Unfortunately, if the oil pressure gauge is showing low oil pressure and/or even lower oil pressure after the engine warms up or the light starts flickering when the engine warms up... when that happens you probably DO have an oil pressure problem. When babbit bearings start to wear out the gap between the bearing and the crankshaft increases and the oil leaks out too quickly for the pump to be able to maintain oil pressure. When that happens, the ONLY option is to rebuild or replace the engine.
But if it's a faulty oil sending unit it could cause the oil pressure light to come on steady or it might cause the oil pressure light to not come on at all, even when the engine is not running. Also the sending unit could make you oil gauge show no oil pressure or really high pressure!
10-28-2008, 06:43 PM #5
its weird man the oil light only comes on when i get on it and the pressure drops then when i let off the light goes off and the pressure goes back up.
10-28-2008, 07:08 PM #6
It is possibly the drain back holes in the engine and they are partially plugged up. Once it pumps all the oil up into the engine, and it doesn't drain back quick enough, the pump has none or little to pump, so the pressure will drop off. When an engine gets sludged up, this is what happens.
The best thing to do is install a shop gauge into the oil pressure sensor plug/hole and find out if the motor has oil pressure problems or if it's electrical problems.
10-28-2008, 07:21 PM #7
just happened too me. had an oil leak.
10-28-2008, 07:28 PM #8Slow'er'Ass
- Thornton, CO
Does this happen in 3rd and 4th gears?
Fill to 6 quarts instead of 5.5 next time and report back.
Lowered, HID's, tinted.
10-28-2008, 07:46 PM #9
hmm... i wonder how i would find out where the oil pressure sensor hole/plug is
10-28-2008, 07:52 PM #10
what oil are u running? strait weight or multi-viscosity? dino (conventional) or synthetic? checkin your oil hot or cold?
10-28-2008, 08:01 PM #11
10-29-2008, 10:28 AM #12
10-29-2008, 11:36 AM #13
10-29-2008, 12:40 PM #14
10-30-2008, 03:34 AM #15
Mine did that when it was down 2 quarts....ops
. Put some oil in the thing!
11-02-2008, 06:08 AM #16
a buddy a mine had exact same problem and his oil pickup fell off his pickup tube. i suggest runnin a mechanical gauge to see what's really goin on...and not drivin it till ya do. if yer mech gauge says the same thing ya need to start tearin into that thing.
ZERO Oil Pressure
By jfl330 in forum General HelpReplies: 5Last Post: 07-22-2013, 08:21 AM -
Help: oil pressure
By Z28boy2000 in forum General HelpReplies: 16Last Post: 07-14-2009, 07:32 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
