Results 1 to 17 of 17
Thread: oil pressure
    2000 Camaro B4C
    oil pressure
    ive been noticing lately that my oil pressure shoots up really high reat 80 when i have my car WOT is this normal... i just changed my oil also. the pressure seems to always be high is this a problem
    USA
    Velocity Yellow
    2008 Corvette Z06
    Normal, mine does the same.
    2018 Tahoe - Silver - OEM
    2000 Camaro B4C
    yeah i was hoping i was just paranoid
    2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
    Junior Member wantedcamaro's Avatar
    Port St. Lucie, Florida
    1998 SS M6 T-TOPS
    me too, mine is a 98 and does the same thing
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    mine doesnt go to 80...60 is tops for me...opsi is measuring resistance ..so there can be alot of things going on there..id go seafoam your car..that might help..what oil are you using/filter ? and what are your intervals?
    Junior Member playboy's Avatar
    Apr 2009
    evergreen Park IL
    1998 Camaro Z28
    mines just the opposite, my car goes between 40 and 60 sometimes even drops down to 30 any ideas?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by playboy View Post
    Normal wear
    Pittsburgh
    2008 Hummer H3
    Wink
    Quote Originally Posted by Z28boy2000 View Post
    I got my Camaro a few years ago, with under 30k. Mine never goes higher than about 65, and never lower than 55. I'm still under 80k with no change.
    I'd say you're okay too. Just as long as it's not going too low or reading nothing at all you're good.
    おれわCamaroがいじん! chaosinfinite's Avatar
    Washington D.C.
    1998 Chevrolet Camaro SS
    Sorry for reviving the thread, but I am having the same issues. Turn my car on while the engine is "cold" the oil pressure will jump up to 60 while I am on the throttle and go down to 50 when I am not. If my engine is hot, and I am in traffic it will go down to 25 sometimes and the needle will shake right there, and on other occasions it will stay at 30. When I put my foot on the gas it will jump up to 45-50. I have not changed the oil in a year. Last time I checked (A month ago) my oil was still full. I used 10w30 Mobile 1 Syn oil w/ Mobile 1 oil filter. Some people I asked said that it could be my oil pressure sensor going bad? Which can also throw my transmission into a "safe mode" and cause me to skip gears while I am driving (which does happen). Any suggestions would be greatly appreciated! Thanks!
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Quote Originally Posted by chaosinfinite View Post
    How many miles are on the car?
    If you havn't changed your oil in a year you could be in for a not so cheap repair down the road. synthetic oils will break down and will rust parts if they sit for a period of time.
    When was the last time the trans fluid and filter were changed?
    Washington D.C.
    I don't drive much on it though. The car has 98,000 miles on it. It is due for a transmission fluid/filter change, but would just that be the cause for the transmission? Seems kind of farfetched when I think about it, but on the other end it could be so simple to have a problem like that. However if it is then that will be an easy fix.
    Shepherd, Michigan
    98' trans am
    while still in the norm...it might be signs of either 1. your opsu is going out..2. your oil pump is getting near its end...or 3. both
    Washington D.C.
    Well, I will change the oil, trans fluid/filter, and if that does not solve the problem then I know where to look too next. Where is the OPCU located by the way? I am just going to try and fix it up and sell it ASAP. I want a C5 Vette now, so it is time to save up and move on.
    Shepherd, Michigan
    98' trans am
    the vettes will have similar issues ..same engine
    the opsu is located behind the intake manifold on the driver side of the block
    Washington D.C.
    Thats fine. I am not getting rid of the Camaro because of maintenance issues or w/e. I just want a Vette now. Thanks for the location info. The sensor is not that expensive to replace is it? Can you get them from like advanceauto if necessary?
    Shepherd, Michigan
    98' trans am
    yup for around 60 i believe
    Washington D.C.
    Awesome...Thanks for your help.
  1. ZERO Oil Pressure
    By jfl330 in forum General Help
    Last Post: 07-22-2013, 08:21 AM
  2. Help: Oil pressure goes down!??
    By 98T/A.SNAKEATER_ in forum General Help
    Last Post: 11-02-2008, 06:08 AM
  3. Replies: 3
    Last Post: 04-01-2006, 03:59 PM
  4. Looking for gauges! nitrous pressure, fuel pressure!
    By texasss in forum Parts Wanted / Trade
    Last Post: 10-29-2005, 09:05 AM
