Results 1 to 1 of 1
Thread: P0342 camshaft pos sensor
05-07-2013, 05:07 AM #1
So this code came up today on 1998 Trans Am. The car cranks and doesnt start UNLESS I hold the gas pedal down a little bit. After I get it started it wont idle until after a few minutes of holding the gas pedal down a little and it warms up a tad. I can drive it and it performs flawless after it warms up. No problems at red lights, no power loss, no issues except for the light being on. My question is, if the sensor is bad, will the car still run and perform this way, or do you guys think I have a wiring issue? I havent removed the intake in over 8 years so i didnt damage or pinch the wires. I reached behind the manifold and made sure the connection was tight and all was well. My problem is I really dont wanna remove the manifold just to replace this and find out something else is the issue. Thanks in advance for your help.
Question: 03 durango crankshaft sensor and camshaft
By JayTA98 in forum General HelpReplies: 4Last Post: 05-16-2011, 08:41 AM -
Camshaft Sensor Replacement
By regerror6 in forum Internal EngineReplies: 7Last Post: 04-28-2009, 02:49 PM -
Question: camshaft pos. sensor
By joker in forum Computer & TuningReplies: 3Last Post: 04-27-2008, 10:37 PM -
Camshaft position sensor
By chris99SS in forum Internal EngineReplies: 2Last Post: 07-19-2007, 05:03 PM -
PO342 Camshaft Position Sensor low input code?
By yellowv in forum Computer & TuningReplies: 1Last Post: 04-12-2007, 09:19 PM
