Results 1 to 3 of 3
Thread: Camshaft position sensor
07-17-2007, 08:02 PM #1Junior Member
- Jul 2007
- Camp Pendleton Ca
Blue- 99 Camaro SS
Code P0341,P0342 popped up on my 99 SS where is it located and is it a DIY job.
07-19-2007, 01:57 PM #2Member
- May 2007
- houston
black- 2001 z28
its directly above the cam at the back of the engine, right behind the intake. it is a pain in the butt to get to, good luck!!
07-19-2007, 05:03 PM #3
not really hard to do. remove the intake with fuel rails, fuel line and TB attached. then easy access. only thing to watch for is breaking the oil pressure switch.
P0343 DTC P0343 Camshaft Position (CMP) Sensor Circuit High
By Camaro98Z/28 in forum General HelpReplies: 11Last Post: 10-16-2013, 07:57 AM -
crank position sensor
By tbias in forum General HelpReplies: 24Last Post: 12-26-2008, 09:40 AM -
cam position sensor
By general23cmp in forum General HelpReplies: 3Last Post: 02-20-2008, 05:47 PM -
PO342 Camshaft Position Sensor low input code?
By yellowv in forum Computer & TuningReplies: 1Last Post: 04-12-2007, 09:19 PM -
Cam sensor position error??
By zero_proto in forum Computer & TuningReplies: 7Last Post: 01-06-2007, 06:20 PM
