    Dublin, OH
    2000 Trans Am WS6
    Camshaft Sensor Replacement
    Quick question. What is a fair price to pay for a camshaft sensor replacement (parts/labor)?
    Feb 2006
    MD
    Labor time is 3 hours. The sensor is about $75. At $100/hr labor (average dealer) figure $375 total. Independants usually charge less labor, so perhaps only around $325.
    You must also figure in the crank relearn procedure that any decent dealer should do. Some charge, some don't - it could be as much as 1 hour labor.. Few independants can even do the procedure.
    Dublin, OH
    2000 Trans Am WS6
    Thanks Marc!
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    Do it yourself and save yourself a couple hundred, its actually very easy!
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by Marc 85Z28 View Post
    The re-learn data deals with CPS and reluctor relationship/variations and should not have to be done with a cam sensor swap.
    Feb 2006
    MD
    I know that. But GM does recommend the procedure when anything is changed/touched that relates to either engine timing or engine timing monitoring systems. I will try to find the now superceded TSB with that note in it...
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    I wouldn't say it's surprising to see it suggested; I wonder what the reasoning is...
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    MONEY
    i know you knew that but ehhh.
  1. P0342 camshaft pos sensor
    By RONS98TA in forum Computer & Tuning
    Last Post: 05-07-2013, 05:07 AM
  2. Question: 03 durango crankshaft sensor and camshaft
    By JayTA98 in forum General Help
    Last Post: 05-16-2011, 08:41 AM
  3. Question: camshaft pos. sensor
    By joker in forum Computer & Tuning
    Last Post: 04-27-2008, 10:37 PM
  4. Camshaft position sensor
    By chris99SS in forum Internal Engine
    Last Post: 07-19-2007, 05:03 PM
  5. PO342 Camshaft Position Sensor low input code?
    By yellowv in forum Computer & Tuning
    Last Post: 04-12-2007, 09:19 PM
