Results 1 to 1 of 1
05-06-2013, 06:20 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Solid, Hydraulic, Flat-Tappet, and Roller Cams - How It Work
Solid, Hydraulic, Flat-Tappet, and Roller Cams - How It Works
With horsepower seemingly growing on trees these days, picking a set of high-flow cylinder heads for your engine combination is the easy part.With horsepower seemingly growing on trees these days, picking a set of high-flow cylinder heads for your engine combination is the easy part. A mother load of rotating assemblies and aftermarket blocks means that building a big-cube short-block to take advantage of all that airflow isn't exactly difficult, either. With the top and bottom end of an engine build covered, the wild card in the horsepower equation often comes down to the camshaft. While it's true that manufacturers offer a diverse range of off-the-shelf camshafts for every conceivable combination, several important decisions must be made before you even narrow the field of part numbers down to a list of finalists.
a
Photo Gallery: Solid, Hydraulic, Flat-Tappet, and Roller Cams - Chevy High Performance Magazine
Solid, Hydraulic, Flat-Tappet, and Roller Cams - How It Works | Digg It | Add to del.icio.us
More...
Comp Cams Hydraulic Roller Cam Installation - Project Pure P
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 11-01-2013, 07:50 PM -
Flat-Tappet Cams and Worn Down Engines - The Perfe
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 08-09-2010, 05:40 PM -
LS1 Comp Cams Hydraulic Roller Camshaft Upgrade -
By Ed Blown Vert in forum Camaro / SSReplies: 2Last Post: 01-01-2009, 04:17 PM -
Solid Roller Cams - Rollin' Hard
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 02-11-2008, 10:00 PM -
Solid Roller or Hydraulic Roller?
By KiD WiCKeD in forum Internal EngineReplies: 4Last Post: 01-02-2008, 07:55 AM
