    Member KiD WiCKeD's Avatar
    Bentonville, AR
    '02 Trans Am WS6
    Solid Roller or Hydraulic Roller?
    Just curious on peoples thoughts between the 2 before I decide. It's driven pretty often but not gently ever LoL. Gonna upgrade both the cam and head assembly. Heads I think i'm gonna go for the Trick Flow CNC Ported Heads w/ 64cc Chambers and 215cc Intake Runners.
    Bentonville, AR
    '02 Trans Am WS6
    Nobody got any suggestions on this?
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    If you are going with a set of Trick Flow heads I would talk directly with them and get their suggestions and possible a custom grind while you are at it. My first thought though is you will want a hydrolic roller, unless you plan on turning fairly high RPMs.
    Austin, TX
    2002 Trans am WS6 T-top
    I second the motion on high rpm turning with soild roller lifters.
    Feb 2006
    MD
    The hydraulic valvetrain in the LS1 is very good. They can reliably spin up higher than the stock type intake will ever allow. In order to run the solid roller stuff effectively you would need a high dollar single plane or sheetmetal intake setup on a 7500+ RPM engine.
  1. Solid, Hydraulic, Flat-Tappet, and Roller Cams - How It Work
    Last Post: 05-06-2013, 06:20 PM
  2. Hydraulic roller maximum...
    By Mr. Luos in forum Internal Engine
    Last Post: 04-03-2008, 09:44 AM
  3. looking to go solid roller set up, anyone else ???
    By Zboner in forum Internal Engine
    Last Post: 09-13-2007, 01:52 PM
  4. solid roller ls1
    By toysruskid62 in forum Internal Engine
    Last Post: 03-21-2007, 09:53 PM
  5. solid roller cam
    By Duke of Cruel in forum External Engine
    Last Post: 07-02-2006, 10:43 AM
