Results 1 to 3 of 3
12-30-2008, 10:40 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
LS1 Comp Cams Hydraulic Roller Camshaft Upgrade -
LS1 Comp Cams Hydraulic Roller Camshaft Upgrade - Cam'd For Power
Our LS1 from the article "Magnificent" is back again. This time were upgrading to a blower specific camshaft from Comp Cams to see if it makes a difference.The LS combos have the potential to make ground-pounding power, even in almost-stock trim. As usual, our bellies weren't yet full, though, and our minds were on the buzz for something more. We just knew our LS1 had more under its skin. Last month we left you with a stout LS1 package ("Magnificent," Jan. '09) that consisted of an LS1 with built internals, including the factory forged crank, a set of Probe 4340 lightweight I-beam rods, and lower-compression SRS series pistons. We topped it off with a set of Trick Flow's GenX Street/Strip CNC-ported lungs for deep breathing. For bump, we used Comp Cams' 230/236 hydraulic roller cam with 0.591/0.601-inch intake/exhaust on a 115-degree lobe separation.
Photo Gallery: LS1 Comp Cams Hydraulic Roller Camshaft Upgrade - Chevy High Performance
More...
01-01-2009, 03:56 PM #2
I didn't know that they made a tool that pushed the lifters up and out of the way so that the cam could be swapped with the heads still intact. Anyone know where to get this tool?
01-01-2009, 04:17 PM #3
Thunderracing.com
Summitracing.com
Comp Cams Hydraulic Roller Cam Installation - Project Pure P
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 11-01-2013, 07:50 PM -
Solid, Hydraulic, Flat-Tappet, and Roller Cams - How It Work
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-06-2013, 06:20 PM -
Comp Cams Camshaft Technology Insite - CHP Inside
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-26-2008, 05:00 PM -
FS: Barely used Comp Cams LS1 camshaft
By Chevythunder17 in forum Parts For Sale / TradeReplies: 5Last Post: 04-03-2007, 12:41 AM -
Comp Cams Roller Rockers: Noise?
By Three cams short in forum Internal EngineReplies: 5Last Post: 11-04-2005, 03:42 AM
