Results 1 to 20 of 30
Thread: 500hp?
04-13-2006, 10:41 PM #1
500hp?
how can i make 500 hp with no turbo or supercharger? what would i have to do
04-13-2006, 10:44 PM #2your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
heads, cam, intake, exhaust, lid, maybe n2o, start there. but remember it doesn't matter how much you have, if you can't put it to the ground.
04-14-2006, 05:04 AM #3member since may 2000
- Dec 2002
- n/w chicago
best way to do it would be use a 402 engine and go from there.
as for the 346ci ls1, its not gonna be all to easy.
the car wont all too streetable.
to get to around 500 rwhp, youll need a big cam like a lg g5x3 cam, afr heads, fast intake, nick williams throttle body, long tube headers computer tuning and so on.
even with above, i dont see above making more than 450 to the rear2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
04-14-2006, 05:35 AM #4Grand Imperial Wizard
- Retired Outlaw Sum Bitch
I got 500RWHP from my LS1....H/C...Headers/Intakes/Ported-Polished TB and a 100 shot of nitrous....didnt last long though....LS1 can't take it....unless of course you build/forge the bottom end...then of course you have spent more/as much money as you would spend if you just dropped a 402 forged stroker motor in....and a LS1 aint gonna run with a stroker....if your goal is 500RWHP get a 383 or 402/408 Stroker and have at it
This is my signature. It is mine. Nobody else has one like it.
04-14-2006, 08:57 PM #5
i dont want to use nitrous i forgot to say that in my post. i want to be all motor. u guys are saying that even if i did it would not be able to handle it?
04-14-2006, 10:35 PM #6
Making the 500 with a stroker motor isn't hard. Making the stock rear last is. Getting an A4 to live behind 500 horsepower isn't all that easy either. I don't know what transmission you have. If it's a manual, hooking up 500 horsepower is going to be a challenge. 500 horsepower is a number that seems to be thrown around all the time these days. Just remember that's a whole lotta power.
04-15-2006, 05:27 AM #7member since may 2000
- Dec 2002
- n/w chicago
500 from a stock cubic inch ls1 without a power adder is not going to happen.
Originally Posted by fastz99
04-15-2006, 05:38 AM #8juiced00ssGuest
nope dont think so either. My buddies ta has afr heads, cam, intake, longtubes,all motor he is laying down around 430 to 450. My car with just a cam, 125 wet shot, and a loudmouth with stock cats and manifolds is laying down 466 rwhp and 525 rwtq with no problems. As soon as i do my longtubes and y pipe i will have my 500hp with stock heads. And i have almost 90k on my car. So doing a H/C package with a shot of juice or a F/I setup shouldnt be a problem, as long as you have the money.
04-15-2006, 02:11 PM #9Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
i just read a thread that someone put down over 500 with carteks stage 4 heads and cam, 90/90 setup and on the stock bottom end with the exception of better rod bolts. not saying its true or possible, just saying I just read it. dont remember if it had a graph
04-15-2006, 02:15 PM #10
04-15-2006, 02:29 PM #11Junior Member
- Jan 2006
- T-Town
silver- 02 Pontiac Trans Am WS6
My 408ci put down 596 on the engine dyno and 505ish at the rear wheels...Then you can always add a power adder
2002 Trans Am WS6 408ci Stroker Motor
150 Shot NOS Pacesetter Long Tubes
Magnaflow Exhaust Eibach Prokit
19x10 fronts, 19x11 back CCW Wheels
(2) 12 Kicker Squares 1400watt Kicker 2 channel
04-15-2006, 09:06 PM #12your parts guy!!!
- cleveland ohio
ok i have to ask? i keep getting the emails on this thread. are we talk 500 hp on motor, or 500 at wheels, that's a big difference someone fill me please.
04-15-2006, 09:58 PM #13
500 hp to the wheels
04-15-2006, 11:52 PM #14The VCBoiz
- Houston
Pewter SS- 2001
500rwhp can be done on a stock bottom end. Good set of heads increasing compression and supporting mods. Might as well build a new motor though.
04-16-2006, 05:28 AM #15
So it doesnt matter if its an ls1 or ls6, as long as the cubes are starting at 383 and up, plus supporting mods, you should be close to or at 500hp?
04-17-2006, 06:59 PM #16Junior Member
- Dec 2005
- AL
Black- 1998 TransAm
All you need to do is purchase this guys car. He got it up to 435+RWHP without heads, cam, nitrous, or FI of any kind on the stock block 346ci LS1. I'd buy his and get a good set of heads and a wild cam and you should be there no problem.
04-18-2006, 04:21 AM #17
i think you should concentrate more on how "fast" you want your car then how much power you want it to make. There's alot of guys with ~420-440 rwhp cam only that run 10's with proper setup.
04-18-2006, 10:19 AM #18Senior Member
- Aug 2003
- Honolulu HI
that was going to be my next point. If your goal is just 500 hp, then dont expect to be able to show it off on the street. The car will more than likely be a dog till about 4k or so. This is gonna be a top end only car. Is there a certain ET or trap you want?
Originally Posted by 98_Formula
04-18-2006, 01:14 PM #19
i want to run mid to low 10s. what kind of cam did they have and what did they do to get it to run that?
04-18-2006, 03:21 PM #20
the cams that htose people run are generally the TREX, also the LG G5x4 cam, and theres now a new one called the "trex killer" which is running like a 10.2x or maybe even a 10.1x. They also have supporting mods like the Fast 90/90, high stall, generally 4000 - 5500, slicks and skinnies, etc. Also most have some weight reduction, some have alot of weight reduction.
of course full exhaust and bolt ons! and there gearing is usually 4.10+.
heres the fastest "cam only" list form ls1 tech, you can see there full setup, raceweight, cam, gears, etc. it will give you an idea of where u'll want to be for the cam only 10 sec ride.
http://www.ls1tech.com/forums/showth...ht=fastest+cam
with those type of cams you need to fully upgrade your valve train and also gonna want to upgrade your rod bolts, becuz you'll want to spin your ls1 upwards of 7500 rpm!Last edited by 98_Formula; 04-18-2006 at 03:30 PM.
500hp v6 project
By Forced_Firebird in forum V6Replies: 85Last Post: 12-02-2009, 11:52 PM -
500hp which clutch?????
By tonyjnjz in forum Manual TransmissionReplies: 19Last Post: 10-01-2007, 08:49 AM -
475 to 500HP
By Niteowl94 in forum General HelpReplies: 8Last Post: 06-13-2007, 03:54 AM -
best 500Hp
By dandm69 in forum General HelpReplies: 6Last Post: 03-06-2007, 05:31 PM -
Have a Porsche 914 with an LS6 500HP
By porsche914ls6 in forum General HelpReplies: 3Last Post: 09-03-2006, 05:22 AM
