Results 1 to 15 of 15
    Experienced Old Fart jfl330's Avatar
    Mar 2011
    Tampa, FL
    '02 35th SS LE SLP#1084
    T56 Related Questions.....
    My 02' SS/LE has 123K miles on it. I have put the last 10K on.
    Since I got it, if you shift into 5th under power, it will grind/grab. If you slowly shift into 5th, no problem.
    When I let clutch out in 1st, I am getting a rattle that goes away as soon as full engagement happens.
    Other than 5th issue, trans is perfect.
    What is best course of action?
    Thanks.
    Jon
    __________________
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I sounds like your syncro's may be on the way out. If that is the case then a rebuild is in your near future.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    The first gear issue sounds like clutch chatter....how old is the clutch?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Aside from J's question, does it ever pop out of gear?
    Mar 2011
    Tampa, FL
    I assume original, 123K miles.
    Jon
    - - - Updated - - -
    No, other than grab/grind going into 5th under power, trans is perfect.
    Jon
    Since it's only 5th and you hear grinding, I'm going to guess it's your 5th gear synchro that's on its way out.
    Typically though, those are less prone to go bad because most people don't shift into 5th at WOT. 5th is an overdrive gear and I would never recommend shifting hard into it.
    Laurel, Maryland
    2000 Grand Prix GTP
    Mar 2011
    Tampa, FL
    This is my 5th LS1 T56 vehicle. 5th has done this since I bought it 10K miles ago. I have always treated 5th and 6th as granny shifts but did not have the pleasure of owning this one since new. I believe I am the third owner.
    So I guess a new clutch (recommendations?) and a 5th/6th cluster rebuild is in order.
    Jon
    Laurel, Maryland
    2000 Grand Prix GTP
    Monster Clutches are god in the LSx world.
    Mar 2011
    Tampa, FL
    For a daily driver?
    Jon
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by jfl330 View Post
    For a daily driver?
    Jon
    Get a Stage 1 or 2. I'm upgrading my Stage 4 to a Stage 5 soon and I'll drive it to work in dress clothes on nice days without question.
    You get used to it. Like Jeremy, I also have a pretty aggressive clutch (Spec Stage 3+) rated at 850 lb-ft and I have zero issues driving the car in stop/go traffic. Couldn't even tell you what a stock clutch feels like anymore, but I can say I don't miss it any.
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    For a daily driver?
    Jon
    I'm getting ready to put in a LS7 clutch with a Tick master cylinder there are some good wright ups on here to maybe give you some other ideas...
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
    Jun 2011
    Branchville, NJ
    Silver & Blue
    I like the LS7 as well. Good clutch, fits perfect, easy on the left leg and reliable.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    I liked my LS7 with the Tick as well....it was REALLY grabby the first few hundred miles, stalled it a lot...but after that it was like butter...I could even start in 5th gear from a dead stop.
  1. HOW TO'S: Drivetrain related..
    By ninobrn99 in forum Drivetrain
    Last Post: 05-30-2014, 06:59 AM
  2. Need some help from LS1.com mechanics (Non LS1 related)
    By blackSS01 in forum Almost Anything Goes
    Last Post: 10-12-2013, 04:25 PM
  3. Help: possible oil related problem
    By formulajman in forum General Help
    Last Post: 06-14-2011, 04:55 PM
  4. I have an idea, oil related!!
    Last Post: 04-19-2008, 05:43 PM
  5. I need some help please. (A/C related)
    By DownSouth325 in forum General Help
    Last Post: 06-27-2007, 12:36 PM
