    Wisconsin
    2001 Camaro SS M6
    Need some help from LS1.com mechanics (Non LS1 related)
    Need some help for a buddy who has a 95 Silverado 5.7L which he has converted to a 6.2L (Stock block) It is a 2 bolt main
    with a 1 piece rear main seal. Question is what oil pan he needs? With stock oil pan he has no clearance for the rod
    bolts, when rotating the motor they nick the pan just barely but enough that you can't leave it obviously. We both are
    unfamilar with doing a conversion like this but it didn't stop us
    The truck is a 4X4 1500 if that matters, so has anyone did this or know anyone that has did this conversion? Not sure where
    to post this since I rarely get out of AAG anymore due to slowness of the board now a days and totally not LS1 related.
    So to wrap it up in a nut shell:
    1995 Silverado 1500
    4X4
    Stock engine bored/stroked from 5.7L to 6.2L
    Rod bolts not clearing oil pan with larger crank
    Need Oil pan that will work
    Thanks for any answer I can get
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Hammer mod??
    Trying to remember how much room is there for a deeper pan
    Wisconsin
    2001 Camaro SS M6
    He told me he attempted hammer mod but it leaks a bit from the gasket due to slight bend on the pan now. He measured and he has 1.5 in to clear all day.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Sounds like you need an aftermarket pan. You would also have to get a oil pump pickup to match. Would this fit? JEGS Performance Products 50204 JEGS Aluminum Oil Pan. You could also try and call a dealer. GMperformance parts makes a 383 crate motor that fits that truck. They should be able to get the part number for the pan and pickup they use.
    Wisconsin
    2001 Camaro SS M6
    I will have him check gm performance.....why didn't I think of that
  1. no boat mechanics here?
    Last Post: 05-23-2009, 08:08 PM
  2. mechanics
    By niterunnr in forum Almost Anything Goes
    Last Post: 07-12-2008, 02:52 PM
  3. Any Diesel Mechanics
    By Red on Red WS6 in forum Almost Anything Goes
    Last Post: 03-19-2008, 11:33 PM
  4. Dealer mechanics
    By rideon1200 in forum General Help
    Last Post: 12-10-2007, 11:43 AM
  5. Mechanics inside
    By BIGRED Z in forum Almost Anything Goes
    Last Post: 06-01-2006, 08:54 AM
