    BIGRED Z
    Guest
    Mechanics inside
    Having trouble with the daily driver. It's a 99 Saab 95. Its been surging at idle more noticable in very hot weather with the AC on. Sometimes it will stall. When it surges, you feel it, the tach increases with the surge. It wasn't doing it a lot, and only stalled 2-3 times over the course of 2-3 weeks. Sometimes if I was stuck at a light, I would drop it into neutral and it would stop.
    Thought it might be the MAF sensor, so we took it out and cleaned it up. After we re-installed it, it's worse than ever. Now it starts surging as soon as I take it out of park and stalls almost immediately.
    Any ideas?
    Lori
    Impounded x-40oz-x's Avatar
    1981 g-Body
    My Cutlass is the same way, but i know i need to rebuild the carb.
    I think your problem is the car's a Saab.
    mwhbossman1983
    Guest
    My first guess was mass air meter, try the o2's if that doesn't work have your injectors cleaned, and if that doesn't work have it thrown on a diagnostic
    BIGRED Z
    Guest
    Quote Originally Posted by mwhbossman1983
    Funny you mention that, at first it wasn't throwing a code, no light came on. But after we cleaned the MAF and put it back in, now the check engine light is on. Gonna drop it off to a friend/mechanic Sunday, just trying to get some guesses as to what it might be. My knowledge is limited and trying to collect all the info I can.
    Lori
    mwhbossman1983
    Guest
    cleaning the mass air you could of messed up one of the wires in it, they are very thin.
    Member Wulfe13's Avatar
    St. Louis, MO.
    2000 Pontiac Trans Am WS6
    Sounds like it might be a vacuum leak or (unmetered air)...
    Senior Member whitelightnin99's Avatar
    SC
    yeah i was thinking vacuum leak. i know on my toyota pickup even if the coolant isnt where its supposed to be it has a temp sensor somewhere in there and causes it to surge real bad. im not a mechanic and never even looked under the hood of a Saab but thats all i can think of
    Senior Member MadSeason's Avatar
    Indiana
    cleaning the maf could of made any problem worse... i had a 4 cyl surge before because one of the spark plugs got cracked and it wasn't firing, didn't throw a code
  1. Need some help from LS1.com mechanics (Non LS1 related)
    By blackSS01 in forum Almost Anything Goes
    Last Post: 10-12-2013, 04:25 PM
  2. no boat mechanics here?
    Last Post: 05-23-2009, 08:08 PM
  3. mechanics
    By niterunnr in forum Almost Anything Goes
    Last Post: 07-12-2008, 02:52 PM
  4. Any Diesel Mechanics
    By Red on Red WS6 in forum Almost Anything Goes
    Last Post: 03-19-2008, 11:33 PM
  5. Dealer mechanics
    By rideon1200 in forum General Help
    Last Post: 12-10-2007, 11:43 AM
