Thread: HOW TO'S: Drivetrain related..
10-28-2005, 10:04 AM #1Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
well, here's an attempt to get this place back to what it used to be and to what it needs to be. If you all have anything to add, email me and ill post it up in here. Im looking for all the instructions that come with the LCA's, PHB's, relocation brackets, TA's..all that stuff. Thanks to Kelly for here gear writeup!! ive got some more to add here and to additonal forums, but need to increase the alloted file size limitations.
Nino
GEAR SWAP:
http://www.keliente.com/gears.htm
03-24-2007, 08:27 PM #2
http://www.stealthram.com/gearswap.htm
when i did my gear swap.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
11-11-2007, 02:45 PM #3
Thanks for the how to's. I am an aircraft mechanic by trade, but it's nice to see details of the job before I tear into it since I've never done a gear swap before.
Given that 2.73 gears are for 2 series carrier, and 3.23 and up are for 3 series, what is your opinion on using a spacer (as advertized http://www.speedwaymotors.com/p/3772...nd-Pinion.html )
to install 3.23 or 3.42 etc. gears on a 2 series carrier?
04-21-2008, 05:27 PM #4
07-19-2013, 02:30 PM #5
So i have a 2.73 gear with an A4 and am looking to swap it out. Anyone have a how to and if I have to swap the carrier to a series 3? I'd like to do a 3.73 if possible.
05-30-2014, 06:59 AM #6
Does someone have a sticky on this? The link in the first thread is no more. Thanks!
drivetrain protection...
By blackhawk01 in forum DrivetrainReplies: 0Last Post: 02-29-2008, 04:23 PM -
WTB/ LS1 drivetrain
By MonkiMajyk in forum Parts Wanted / TradeReplies: 2Last Post: 10-13-2006, 11:46 AM -
drivetrain
By bmwmike in forum Parts For Sale / TradeReplies: 1Last Post: 04-10-2006, 01:46 AM -
A4 drivetrain
By pewterz28 in forum Automatic TransmissionReplies: 1Last Post: 01-26-2006, 09:51 AM
