04-12-2006, 07:54 PM #1Junior Member
- Apr 2006
- Brooksville Florida
Teal- 1998 Z28
will a differnt brand of n20 jet make a difference?
I am currently using a zex wet kit with a 125hp set up. NX claims there jets provide more hp...I would be assuming because Zex rates their hp at the crank and NX rates theirs at the wheels this could be true. Anyone else try or heard of this?
Also since I am considering a jet change would a 150 shot be too much on the stock internal as well as the fuel system?
04-13-2006, 07:12 PM #2
ther are different styles of jets. the funnel style, like NX, seem to do better. the whole crank vs rwhp given the same jetting i've been there and done that trying to figure it out. http://stealthram.com/nxnytrex.htm
as far as running 150 hp, i will tell you no. some might tell you yes. i run 130 rwhp on stock fuel system in both of my cars.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
04-13-2006, 07:42 PM #3
My car use to have a 150 NX on it, handled it well, and yes If I was you I would sell that Zex kit and go with TNT or NX. They are much better systems and are rated rwhp. I think zex is more of a import nitrous system. Gets the job done, but not the best
04-22-2006, 05:41 PM #4Junior Member
- Apr 2006
- Florida
Originally Posted by Cobra2WS6
i agree
Question: How big of a difference do sway bars make?
By Tylumpy in forum Suspension and HandlingReplies: 5Last Post: 06-09-2011, 09:19 PM -
Question: Does the oil filter make a difference?
By ldurham in forum General HelpReplies: 20Last Post: 08-25-2010, 12:21 PM -
LS1 intake and TB make a difference on 5.3?
By lsgunner28 in forum External EngineReplies: 6Last Post: 04-08-2010, 07:03 AM -
does it really make a big difference
By purplebat66 in forum Firebird / WS6Replies: 27Last Post: 05-29-2008, 10:11 AM -
What kind of difference would AFR heads make?
By the_husk in forum Internal EngineReplies: 0Last Post: 04-13-2008, 07:02 PM
