Results 1 to 15 of 15
Thread: Spring shock upgrade
01-31-2013, 03:12 AM #1Member
- May 2006
- roosendaal , netherlands
white- 2000 transam ram air WS6
Hey Guys
I am currently runing adjustable eibach springs with Kyb shocks
THE ride is verf poor i am gonna upgrade to new springs thinking of strano but i have send hij 5 Emails over Ã* periode of 2 months and try,d calling 3 times and no response . What els is Ã* good brand springs .?
I also have Ã* umi panhard bar adjustable And relocating brackets.
Should I keep the shocks or change to koni yellow ?
Are the worth the 1000 dollars , where I live whe have a lot of speed bumps and stuff so need good suspension I do wanna stay lowered
I am running 20" neeper moxy rims
Please let me know
Thanks
Greetings from the Netherlands
02-04-2013, 11:06 PM #2Member
- May 2006
Nobody ?
02-05-2013, 05:47 AM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
Well, why is your ride poor. Too hard, soft, bad in the corners, too much bounce ? Also I would start with the shocks and see if that clears up the problem. You may need to switch to UMI control arms. We need more info.
02-05-2013, 06:41 AM #4Member
- May 2006
Hello the front is way to tight and the back to loose the problem is when i drive my car past 80 m/h i just don,t trust the car any more the spring set that i have is a eibach adjustable soo with a ring that you turn up you adjust the ride height which means that the spring only gets shorter because of that there is not much room to travel any more and the kyb shocks i should have got koni,s to begin with but i was to tight at that moment hahahah and also when the shipped my car i think the tight the frame down because when i got my car here to the netherlands the shocks have never been the same!! Greetings
02-06-2013, 07:10 PM #5Former Mopar Man
- Jun 2011
- Branchville, NJ
Do you have access to air tools and a lift.
02-07-2013, 01:17 PM #6
If you were thinking Strano's (and I'm surprised he hasn't gotten back to you, he's usually pretty good), Then I would say BMR's are the next safest bet. They are actually rip offs of Strano's, with almost the exact amount of drop and same spring rates. I might get in trouble for saying that, but Oh well. And alot of R&D went into the Strano's as you may already know. I went with Strano's and my car actually rode a bit smoother on them vs stock, with improved handling, of course. As far as the shocks go, people that run them say they are pretty stiff even on their softest setting. I've never ran Koni's, so I cannot speak for them, although I certainly wouldcould not drop a grand on a set of shocks. SLP Bilsteins are the nest best bet if you don't have the money for the Koni's. All depends on how much you want to spend.
02-07-2013, 02:12 PM #7
Good advice above - and it's been well documented all over about the BMR's and Sam. Odd you never heard back from him. I've called him and spoke to him several times and he's always been extremely helpful.
I'm running the Strano lowering springs with the Koni 4/4's. Zero issues for the last 3 years. Love my car's stance and the ride quality is pretty awesome.
03-09-2013, 05:10 AM #8
03-09-2013, 09:29 AM #9Boost gets you laid, unless your name is Jon.
10-28-2013, 11:36 PM #10
Dude I'm running the same combo. Not bad on nice smooth roads, but ill be damned when you hit a pothole its send your spine through your asshole. I just bought some Strano's ill keep you updated on how they ride with the kyb's.
10-29-2013, 02:43 AM #11
I have kept my stock springs and ride height due to our wonderful roads around here. Recently installed Koni Double Adjustable shocks up front and am pleased with the result. Even though I have them set for track duty, the ride on the street is better than the stockers. I also ditched the front sway bar in the process and haven't noticed any real difference in how the front end behaves. Next step will be to upgrade the rear shocks.
11-06-2013, 11:07 PM #12
Just installed the Strano springs and new tires the other day. Wow! what a difference, Ride height is still low ~N~ sexy but rides 60% better. Definately worth the upgrade. Kyb's set at 4 in rear and 5 up front. Firm ride, definately not harsh anymore. Worth the $$.
12-16-2013, 12:41 PM #13
12-17-2013, 02:41 AM #14
Stranos and Konis are always the recommended choice around here. I don't think you'll find any unhappy members running this combination to lower their cars.
02-14-2014, 07:19 AM #15
sam got right back to me too. I just ordered and put on his springs and swaybars within the last two months. I already had konis.
He has developed his setup from alot of track time. I didn't want to have to re-invent the wheel. The ride is good, The car will ride great in the Netherlands, our roads in the Northeast are terrible.
I'd give him another call. Of course get koni. Support your local economy
Lou
Question: Best spring and shock set up????
By Musclecargt71 in forum Suspension and HandlingReplies: 6Last Post: 08-17-2009, 05:46 PM -
Question: About the alignment after a spring/shock upgrade..
By RaceMyLS1 in forum Suspension and HandlingReplies: 7Last Post: 02-23-2009, 09:38 AM -
98 WS6 with 1 LE spring rates Shock ?
By zo6machine in forum Suspension and HandlingReplies: 3Last Post: 01-08-2007, 01:26 PM -
New shock/spring recommendation
By Banshee1967 in forum Suspension and HandlingReplies: 3Last Post: 10-29-2006, 03:57 PM -
1LE Shock/Spring help please
By funlman in forum Suspension and HandlingReplies: 1Last Post: 12-05-2005, 04:15 PM
