    "Car Builder" Musclecargt71's Avatar
    Jul 2009
    Flint, MI
    millenium yellow/green
    '02 CETA, '71 Firebird
    Best spring and shock set up????
    Hi guys,
    Just wondering what you would recommend for a spring and shock replacement. I was looking at the BTS kit from Bilstein, but I heard thats not a very good kit.
    Any input is appreciated.
    What is the primary use of the car?
    Jul 2009
    Flint, MI
    The car will be a weekend cruiser, not a daily driver, drag racer, or auto x. (I say will be cause I'm in the process of reviving it. 2002 CE that was wrecked) I would like the car a bit lower and I don't mind a stiff suspension
    In that case...
    Strano springs with Koni shocks. Best overall performance, and rides very nicely for a lowered car.
    That is what I am running on my car. Expensive, but worth it.
    Jul 2009
    Flint, MI
    Thanks for the input, where is this set up available? Can you get it in a kit, or do you buy the springs and shocks separate?
    Junior Member DesertRat's Avatar
    May 2008
    Brooklyn, NY
    1998 Camaro Z28 conv'
    http://www.stranoparts.com/
    Talk to Sam, he will get you the correct set you need for your car.
    Fort Wayne, IN
    2002 Chevy Camaro SS LE
    2nd recommendation for Strano
    I recommend giving Sam a call and discussing what you want your car to do. Based on my interactions with Sam, he will ask several questions and discuss options with you. FWIW, I am very happy with the springs, shocks and sway bars he recommended.
    Good Luck and let us know what you decide and how you like it.
  1. shock/ spring setup
    By Ramairgod84 in forum Suspension and Handling
    Last Post: 12-03-2009, 10:45 AM
  2. Bilstein shock and spring set
    By 99bluebird in forum Suspension and Handling
    Last Post: 09-05-2007, 07:49 PM
  3. 98 WS6 with 1 LE spring rates Shock ?
    By zo6machine in forum Suspension and Handling
    Last Post: 01-08-2007, 01:26 PM
  4. New shock/spring recommendation
    By Banshee1967 in forum Suspension and Handling
    Last Post: 10-29-2006, 03:57 PM
  5. 1LE Shock/Spring help please
    By funlman in forum Suspension and Handling
    Last Post: 12-05-2005, 04:15 PM
