    Destroyer of Mustangs RaceMyLS1's Avatar
    Mansfield, OH
    Black/Red
    98 Trans Am/99 Firebird
    Question About the alignment after a spring/shock upgrade..
    Next week, I am getting shocks, lowering springs, an adjustable panhard bar, and a new set of tires (on stock rims) installed all at once by a custom shop. The car goes in at 9AM, and I'm not sure how long it will take.. What if it's late and I can't take it to an alignment shop that same night? Will I hurt anything by driving the car home (25 min. drive)?
    How long should it take for a shop to install shocks,springs, and a panhard?
    Also, do alignment shops mess with adjustable panhard bars? The guy at the customs shop said he will get the rear centered as much as possible, but the alignment shops should be able to get it right on the dot..
    Any thoughts?
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    I drove mine for a week before I got the alignment so you should be fine.
    The factory alignment settings call for positive camber but putting on drop springs will alter it to negative which is better for handling anyway.
    heres a link with good Suspension info including alignmemt settings.
    http://www.angelfire.com/my/fastcar/suspension.html
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    no problem driving the car... just remember that the car is not properly aligned... so the steering might be a bit off or the car pulling to a side.
    Just do an alignment as soon as you can.
    Also make sure that when aligning the car not to use the stock camber specs.
    the castor + toe are fine... but try to get a bit of negative camber.... for better wear and cornering grip.
    Eugenio_SS
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by RaceMyLS1 View Post
    Any thoughts?
    the rear centering is more of a visual thing. you're looking to get the tires the same distance away from the outer fenderwell.
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    Quote Originally Posted by Eugenio_SS View Post
    what specs should we tell the shop to but it at?
    orlando, fl
    2014 camaro 2ss/rs
    -0.50 camber both
    +4.30 caster left
    +4.50 caster right
    +0.06 total toe
    Mansfield, OH
    Black/Red
    -0.50 camber both
    +4.30 caster left
    +4.50 caster right
    +0.06 total toe
    So I should write these specs down and take it to the alignment shop and they will do that set-up for me?
    "A blind chimpanzee driving a WS6 with a dead hooker strapped to the hood should be able to put that thing deep into the 13's."
    Jun 2002
    Montreal, CANADA
    triple-black
    or get inside the car while they align it and ask for +4.5' castor.
  1. Spring shock upgrade
    By barryz in forum Suspension and Handling
    Last Post: 02-14-2014, 07:19 AM
  2. Question: Best spring and shock set up????
    By Musclecargt71 in forum Suspension and Handling
    Last Post: 08-17-2009, 05:46 PM
  3. Bilstein shock and spring set
    By 99bluebird in forum Suspension and Handling
    Last Post: 09-05-2007, 07:49 PM
  4. Alignment after doing a spring/shock install?
    By bad99ta in forum Suspension and Handling
    Last Post: 06-20-2006, 09:30 AM
  5. 1LE Shock/Spring help please
    By funlman in forum Suspension and Handling
    Last Post: 12-05-2005, 04:15 PM
