    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Do we have variable runners on our intake manifolds?
    If we do, is it possible for them to malfunction? I get no throttle response below ~2500rpm. Yesterday, I needed to accelerate quickly from about 2 or 3 mph in 1st, and there was quite a bit of lag after WOT. This has been going on for a while, but, I've never needed to WOT from that low. My induction system is clean, so I don't think its a dirty filter or anything like that.
    Thoughts? Car is in Phoenix, if that matters.
    Answer is no
    When is the last time you clean the MAF sensor?
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Okay, so... even though I recently cleaned out the K&N, I went through and cleaned the MAF and the TB. Re-installed the K&N. No difference. Bought a paper filter, installed, and BAM! Instant throttle response. A clear difference in initial response with pedal application. Not a big top end gain, of course, but the problem I was having has been solved. And I'm officially dumping my K&N... too much of a PITA to maintain... and even after cleaning it, it's just too hard to get all the gunk and rocks and bird feathers etc out of the nooks and crannies.... I'm switching back to paper filters every year.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Another convert for a paper filter, eh m?
    At least for our set-up, K&N air filters have proven over and over they are a waste of time/money.
    However, if your K&N was clean, you really should see almost no difference between it and a quality paper filter.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Well, my car came with the K&N from the previous owner. I'm sold on the paper, now. It probably has better filtration, anyway.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by Naaman View Post
    Not probably, it absolutely does.
  1. Intake manifolds?
    By AFWS6 in forum External Engine
    Last Post: 03-06-2011, 04:31 PM
  2. Oil/Dirt in intake and runners
    By corvet786c in forum General Help
    Last Post: 07-17-2009, 01:34 PM
  3. LS6 intake manifold and 227 Intake runners
    By IT_SS in forum Internal Engine
    Last Post: 07-07-2009, 02:11 PM
  4. Question: 227 CC intake runners
    Last Post: 05-29-2009, 11:07 AM
  5. WTT intake manifolds and TB
    By PierreGTO in forum Parts Wanted / Trade
    Last Post: 10-11-2007, 08:37 AM
