Results 1 to 16 of 16
Thread: Oil/Dirt in intake and runners
07-16-2009, 07:16 AM #1Junior Member
- Sep 2005
- Port St. Lucie Fl
Black- 2008 C6 Corvette LS3
I noticed that when we took off the LS1 heads that the runners were very dirty with thick grime. You can see the diffrence where injectors squirt fuel. What causes this how can I prevent it?
07-16-2009, 07:20 AM #2
07-16-2009, 07:20 AM #3Impounded
- Oct 2007
- Beaver Dam KY
Install an Oil Catch Can.
07-16-2009, 07:21 AM #4Impounded
- Oct 2007
- Beaver Dam KY
07-16-2009, 11:51 AM #5Member
- May 2009
- pa
It happens in ALL engines. All you are seeing is the normal carbon build up from the combustion process that happens in the intake. I know you are going to say combustion happens in the cylinders how could it get back into the intake. If you could look inside the intake as the engine was running you would be shocked at what goes on in there. Flash over from the valves opening causes combustion gases and oil to get burnt in the intake.
Try running Techron every 3k miles in the gas, it will help clean. You could run something like Lucas fuel system treatment in the gas all the time. This will keep it clean.
07-16-2009, 12:06 PM #6
07-16-2009, 07:27 PM #7Member
- May 2009
- pa
No it happens in ALL internal combustion engines.......i don't care what the cam specs are.
07-17-2009, 03:04 AM #8Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
07-17-2009, 04:15 AM #9
07-17-2009, 04:20 AM #10Member
- Nov 2008
- harrisburg pa.
07-17-2009, 05:09 AM #11Member
- May 2009
- pa
Its just something that all engines do.....some combustion takes place in the intake. Then as the engine gets older and the valves leak a little more it gets worse. Think about this if a intake valve leaks just 1% those combustion gases are going into the intake manifold where they are going to start burning on the way to to next intake valve that is open. Then also add thie fact that ALL engine also heat soak the intake causing carbon depoists in the intake and on the injectors.< that is a huge reason why injectors get blocked....they block from the heat soak carboning the exit holes in the injectors.
Lesson for today is over...tune in next time for fun with Dick
07-17-2009, 07:17 AM #12
07-17-2009, 07:45 AM #13
To explain a little more, Reversion is exhaust gasses that are getting up through the intake valve during the combustion process,(aka: carbon),,this is completely different than oil in the intake that the original poster is talking about.
The reversion process isn't so much of a problem in cars with stock camshafts. Most lobe seperation angles are spread out as far as 117 degrees to build low speed cylinder pressure by closing that intake valve sooner. Keep the exhaust gasses in the cylinder rather than escaping up through the intake track. If you have a valve seat leaking then you have other issues that need to be addressed.
I've taken 150,000 mile stock motors apart and see more oil issues with worn valve guides coating the intake and exhaust valves than I've seen with reversion.
Granted it does happen even with stock camshafts, it's not enough to even worry about. The biggest issue with these 4th gens is the PCV system that actually sucks the oil into and through the intake system. That's what needs to be addressed and can be stopped.
There is nothing you can do about reversion. And more people are sticking larger camshafts in these cars every day, which makes reversion more prevelant. Those are the ones to keep an eye on. Although it's just a necessary evil we live with. You want to make more high rpm power with a high overlap camshaft, you get reversion.
07-17-2009, 08:32 AM #14Junior Member
- Sep 2005
- Port St. Lucie Fl
I just got new afr heads put on so I know it is no valve leak. I just want to clean intake and dont want that garbage on the new heads. U know what I mean. I just ordered a catch can hope this helps with oil in intake.
07-17-2009, 12:47 PM #15Member
- Nov 2008
- harrisburg pa.
im new to these cars and learning things almost daily, that is next on my list. at113k its a little late to worry about the oil deposits, but at least i wont be mixing the oil into the intake stream, should run better but i dont know if its a seat of the pants improvement though. the can from the ws6 store is a pretty good price, i dont know yet if it works or is just a can without a screen or something to promote the oil and condensation dropping out of the air.
07-17-2009, 01:34 PM #16
Yes,,,reversion that 99RTA mentioned would allow combustion or carbon to come up through the intake valve. I think he got that confused with the oiling problem through the PCV that it appears you are experiencing.
To be sure you can pull the throttle body and stick your hand in the intake just behind the throttle body and feel around,,,if it's oily residue then it's the PCV. You can also pull the PCV apart and check for oil inside the hose, PCV etc... In some cases such as mine, it would back flow (somehow) and puddle up in front of the throttle body in the bottom of the smooth bellow.
The catch can will stop it from entering the intake system.
Do we have variable runners on our intake manifolds?
By Naaman in forum External EngineReplies: 5Last Post: 02-07-2013, 04:06 PM -
LS6 intake manifold and 227 Intake runners
By IT_SS in forum Internal EngineReplies: 4Last Post: 07-07-2009, 02:11 PM -
Question: 227 CC intake runners
By IT_SS in forum Internal EngineReplies: 9Last Post: 05-29-2009, 11:07 AM -
Question for the runners out there
By grandkodiak in forum Almost Anything GoesReplies: 29Last Post: 05-15-2007, 06:16 PM -
15” x 4” front runners
By Trolleyman in forum Wheels and TiresReplies: 2Last Post: 08-24-2006, 02:39 PM
