Thread: Any tips for A/C box removal?
01-18-2013, 10:26 AM #1
I did some searching and cant seem to find anything about removing that big black box that the A/C lines run into by the pcm. It looks like its tucked back in there pretty good and was wondering how difficult it is to get out? Is there any thing to take out first that would make it easier? Also does that dash need to come out to get it out? I was just going to remove the under hood parts because I do not want to pull the dash. and will heat still work?
01-18-2013, 02:00 PM #2Senior Member
- Apr 2010
- Alabama
I just did this
. When I get home I can write up exactly what I did. Simply put no you do not need to remove the dash for the heat to work you would need to keep the heater core and mod the delete panel to work. It isn't hard just time consuming and be prepared for it to come out in a million pieces.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
01-19-2013, 04:26 AM #3
Ok cool. By come out in a million pieces, is that because you have to break it into pieces or that's just how it comes out?
01-19-2013, 06:12 AM #4
I've always refered to this site for exploded detailed views of assemblies before I disassemble anything. This diagram shows the AC box assembly and pretty much everything your gonna be taking out.
AIR DISTRIBUTION SYSTEM. Fits: 1999 Chevrolet Camaro Coupe Gas 8 Cylinder 5.7L | Tonkin Online Parts
01-19-2013, 06:16 AM #5
Actually, this diagram shows everything inside that black box...should help ya out...
A/C & HEATER MODULE ASM. Fits: 1999 Chevrolet Camaro Coupe Gas 8 Cylinder 5.7L | Tonkin Online Parts
01-19-2013, 07:35 AM #6Senior Member
- Apr 2010
- Alabama
You don't have to break it but it is a PIA if you don't. It only came out in a million pieces because I busted all the stuff to actually remove the box for simplicity. A BFG comes in handy.
To get the box out the first thing to do is remove the hose brackets and clamps in the engine bay. Then I loosened all screws I could find around and attaching the two halves of the box together. I actually cut the hoses that protrude from the heater core for ease of removal. Next, get under the glove box and remove the access panel. Believe it is attached by 4 screws and two tabs. Once removed there is a cover that needs to be removed to access the rest of the stuff. Now pull back the carpet to access the lower bolts on the inner side of the box. Remove all visible bolts that are attached to the firewall. Do not mess with the BCM which is the black box on the front right hand side.
There is a cylindrical vacuum piece behind the BCM.
Disconnect and connectors and remove it. Next the weird piece it was sitting on that attaches to the firewall can be removed, this can be unbolted or smacked out with a BFG. I used a BFG since the bolts were extremely hard to gain access to. There is plastic around the heater core which can be removed by smacking it with a hammer and then the heater core should pull out. Next there is a bracket which is attached to the firewall and a block inside of the AC box, I cut it and removed the block. Next on the left hand side there is the fan resistor towards the bottom of the firewall.
I removed this. If all the bolts have been removed from the firewall the box should pull out. What I did was from the engine bay I removed the upper half first and then pulled the lower half out under the glove box.
If you have any other questions do not hesitate to ask.Last edited by 98TransAmWs-6; 01-19-2013 at 07:41 AM.
01-19-2013, 02:46 PM #7Member
- Aug 2011
- pittsburgh,pa
navy blue- 1998 camaro ss
Ta Are you removing all the a/c components? Was thinkin about doin it myself. The a/c does not work anyway. (Compressor). Ive already been running it with the belt off. Just still debating about removing everything. Im sure its just for weight deduction correct?
01-19-2013, 06:03 PM #8
Yes just for weight and to clean up the engine bay. I hadn't had the belt on it on two years. I removed everything but the box section today and that too about 30 minutes. I also a tubular k member so getting to the compressor is easier also.
- - - Updated - - -
01-20-2013, 08:10 AM #9Junior Member
- Nov 2012
- Illinois
pewter- 2000 firebird
how many bolts on the fire wall holding the box in ?
Transmission Removal Tips
By rc74racer in forum GTOReplies: 9Last Post: 02-06-2012, 07:39 AM -
For sale.. Corsa Exhaust tips. Quad tips (2/side)
By 5abivt in forum Parts For Sale / TradeReplies: 2Last Post: 09-05-2009, 11:14 PM -
lower a-arm bushing removal tips/help needed
By 2MuchFun in forum Suspension and HandlingReplies: 7Last Post: 08-20-2007, 04:58 PM -
By 2MuchFun in forum General HelpReplies: 0Last Post: 08-14-2007, 05:58 PM -
Need tips on brake dust removal
By Speedy_Gonzales in forum Showcar and DetailingReplies: 11Last Post: 02-09-2007, 09:55 PM
