08-15-2007, 04:05 AM #1
lower a-arm bushing removal tips/help needed
hey guys, my friend requested your help on his 97 z28, he is replacing the lower left a-arm bushing, the rear one i believe, he cant figure out how to get the bolt out, and he was wondering if any of you expert techs had any ideas on how to do it!! thanks peoples
08-15-2007, 02:13 PM #2
08-16-2007, 02:31 PM #3
he's using a air hammer and it still wont come out.....
08-17-2007, 11:39 AM #4
Heres an install guide from fbody.org:
For lower control arms, only remove one at a time or the axle will rotate and you'll have a fun time puting it back.
Step 7
Jack up car by differential housing so that it is not resting on the jackstands. I know the instructions tell you to only "lift up slightly with jack", but thats BS. The bolts were IMPOSSIBLE to get off with that weight, tension, on the control arm bolts. Just lift the car by the diff. Bolts come out fairly easily.
Take off the rear bolts first.
Step 8
Remove front bolts.
LCA is likely stuck in place with grease/dirt.
Use a wedge to remove.
Clean brackets/bolts/nuts.
Step 9
Slide in new LCA with the grease fittings down.
Front part first, bolt in.
Rear should swing up to bracket. If not, loosen front bolt and swing rear up.
Bolt in rear.
Step 10
Repeat for other side.
08-19-2007, 02:03 PM #5
was this the one on ls1tech where he ended up torching the bolt that was frozen into the bushing sleeve?
08-20-2007, 08:22 AM #6
Not sure...just googled it lol.
08-20-2007, 03:38 PM #7
i was asking the original poster.
08-20-2007, 04:58 PM #8
Question: Lower and upper control arm bushing removal and instalation
By JayTA98 in forum General HelpReplies: 16Last Post: 10-18-2013, 05:03 PM -
lower control arm bushing
By twozs in forum Suspension and HandlingReplies: 5Last Post: 03-30-2011, 05:38 PM -
Removal of trans mount bushing
By TransAm11973 in forum Suspension and HandlingReplies: 4Last Post: 12-31-2007, 12:40 PM -
Pedders bushing removal
By Goatdriver in forum GTOReplies: 0Last Post: 08-26-2007, 06:23 AM -
By 2MuchFun in forum General HelpReplies: 0Last Post: 08-14-2007, 05:58 PM
