Thread: lower control arm bushing
03-29-2011, 04:25 PM #1the cake is a lie
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
ive been hearing a rattle in the right front . its been shitty around here so i finaly got a chance to take the wheel of and all looked suprising good .... EXCEPT for this ....
couple of questions ... do i need to break the lower ball joint and is the spring tension going to be a problem . how hard is it to do ( change the rear lower control arm bushing )
03-29-2011, 10:30 PM #2Senior Member
- Jan 2010
- texas
silver- 2000 formula
03-29-2011, 10:30 PM #3Senior Member
- Jan 2010
- texas
poly......FTW !!!
03-30-2011, 09:12 AM #4Senior Member
- Jan 2010
- texas
yes you do need to break the ball joint......with the car jacked up all the way ......there is no spring tension.......not to hard
03-30-2011, 04:09 PM #5the cake is a lie
- Sep 2005
- hopewell jct, ny
are they pressed in and how hard is it to get to the top of the bolt with a wrench . it looks like it can be secured from the inside ? or the fender side ? unfortunately the budget only calls for a non urethane replacement . thanks for the quick responce
03-30-2011, 05:38 PM #6Senior Member
- Jan 2010
- texas
the top of the bolt is held in with a U clip type thing...you dont even have to hold it with a wrench...i bet the difference in price between polys and rubber is not so much
Question: Lower and upper control arm bushing removal and instalation
By JayTA98 in forum General HelpReplies: 16Last Post: 10-18-2013, 05:03 PM -
rear lower control arm bushing (front right )
By twozs in forum General HelpReplies: 7Last Post: 03-31-2011, 09:56 PM -
Control Arm Bushing Swap - Get In Control
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 07-10-2009, 10:10 AM -
lower a-arm bushing removal tips/help needed
By 2MuchFun in forum Suspension and HandlingReplies: 7Last Post: 08-20-2007, 04:58 PM -
By 2MuchFun in forum General HelpReplies: 0Last Post: 08-14-2007, 05:58 PM
