03-29-2011, 05:50 PM #1the cake is a lie
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
rear lower control arm bushing (front right )
anyone done it . little rattle and found this ...
03-29-2011, 06:21 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I can't remember if the bushing can be replaced, or if the whole arm has to be replaced.
03-29-2011, 07:00 PM #3Senior Member
- Apr 2008
- Madison, WI
I've done similar ones on other GM vehicles. It presses (or pound with a hammer) out. then press or pound a new one in. Sounds easy, but its can be a pain...even with nice tools.
03-29-2011, 10:24 PM #4Senior Member
- Jan 2010
- texas
silver- 2000 formula
or....you can do polys
03-30-2011, 06:12 PM #5the cake is a lie
- Sep 2005
- hopewell jct, ny
the cheaper the part the more time it takes to replace it . rockauto has it for 12 bucks . and like you said alot of work . I'm figuring removal , schlep the control arm to a shop to have the bushing pressed in ( there goes a day with work and all ) and reinstall , then off to the alignment shop right ?
03-31-2011, 07:15 PM #6Senior Member
- Apr 2008
- Madison, WI
yep sounds about right
03-31-2011, 09:14 PM #7Electrical Engineer
- Jul 2009
- North of the Motorcity
Potential excuse for upgraded arms?
03-31-2011, 09:56 PM #8
Unless the arm is damaged, it shouldn't need replaced. You can buy new rubber, or Poly has benefits (and cons).
When i replaced mine, one bushing was too large for my c clamp press. If you have an arbor press they are done in about 5 minutes though.
Whatever you buy will probably require reuse of the metal drum outer and insert, so you will have to remove the rubber. This is REALLY REALLY easy to do if you just take it outside and burn it off with a propane torch or even acetylene. and if you let them cool slowly you shouldn't damage anything.
My advise, just buy poly for both bushings on that arm, then if you can use someones arbor press, or a large bushing press, and have a place/equipment to burn out the bushings, it is cheap and easy.
If you don't have any part of the above, just pay a shop to do it cause its gonna be a bitch.
FYI this was a total pain till i got smart and figured out the above combo of arbor + flame = beer sooner
Question: Lower and upper control arm bushing removal and instalation
By JayTA98 in forum General HelpReplies: 16Last Post: 10-18-2013, 05:03 PM -
By twozs in forum Suspension and HandlingReplies: 5Last Post: 03-30-2011, 05:38 PM -
Front Upper & Lower Control Arm Recommendations
By rockojugs in forum Suspension and HandlingReplies: 11Last Post: 07-07-2010, 10:09 AM -
Question: Front lower control arms
By kool-aide in forum Suspension and HandlingReplies: 3Last Post: 09-01-2008, 04:22 PM -
BMR front lower control arms f/s 93-02 f-body
By billetss in forum Parts For Sale / TradeReplies: 13Last Post: 12-03-2007, 08:48 PM
