Results 1 to 10 of 10
Thread: Transmission Removal Tips
01-25-2012, 06:06 AM #1Member
- Mar 2007
- Gainesville, VA
Any tips to make this easier? I have already turned a simple clucth bleeding into a weekend project by dropping a 11mm deepwell socket into the transmission. I'm going to try a 24" flexible magnet before dropping the tranny but something is telling me this thing is not coming out as easy as it fell in.
01-26-2012, 06:21 AM #2
For the upper bell housing bolts=2 foot extension, two 6" extensions () gives you a slight bow and flex), take a universial joint and loosely wrap a peice of masking tape around it to stiffen it, then on the end of that a short 6 point socket......go in from behind the tail shaft up to the bell bolts, this makes it VERY easy
01-26-2012, 07:55 AM #3Senior Member
- Oct 2008
- Coral Springs, Fl
Remove the starter and try from there
01-26-2012, 09:18 AM #4Member
- Mar 2007
- Gainesville, VA
Didn't really think about that. I will give the flexible magnet and starter a try first.
Thanks for the suggestion about the extensions and tape Mark. I'm hoping to avoid this but if not I'm sure this will help. If I have to drop it I'm going to put the speed bleeder in while I have it out.
01-26-2012, 09:29 AM #5
Good luck man! If it makes you feel any better I dropped the little oil tube bolt for the oil pump down into the oil pan....twice lol 1st time I got it out with a pen magnet, same with the second time, BUT then I dropped the socket in there and had to pull the pan to get it.....to pull the pan I had to drop the whole front suspension lol
01-26-2012, 09:31 AM #6
Also there is a sheetmetal plug in the automatic bell housing you might be able to pop that out and get it from there
01-26-2012, 11:32 AM #7Member
- Mar 2007
- Gainesville, VA
I'm ok with it. At first I was in disbelief that it was even possible to do this, such a bad design. The bottom line is I messed up so I will take my lumps. I have my 08 HD road glide to get around on and when I need a car my GF lets me use her 2011 WRX so it could be worse.
01-26-2012, 04:50 PM #811 years of bangin gears
- Jan 2009
- North Jersey
Hopefully the starter idea works.
01-27-2012, 10:21 AM #9
At the worst with regular hand tools you can have the tranny out in a half hour
02-06-2012, 07:39 AM #10Member
- Mar 2007
- Gainesville, VA
Tried the starter didn't work. Just can't get the magnet in at the right angle to grab it. Tranny is coming out this weekend and I'm installing a speed bleeder. I have a feeling there is more to my hydraulic issue than just bleeding the clutch. I know the MC is the weak link but what if anything can I do with the tranny out to make sure it's not a slave issue? I'm really tired of hydraulic issues with these damn LS cars you would think GM would put an adequate system on a cars with 350+HP. My GTO has 12k miles on it! I may just replace the MC with a tick unit while I'm at it haven't decided yet.
Transmission Removal - Part 1
By pajeff02 in forum Automatic TransmissionReplies: 34Last Post: 02-09-2014, 04:47 AM -
Any tips for A/C box removal?
By TA98 in forum General HelpReplies: 8Last Post: 01-20-2013, 08:10 AM -
2000 T/A, Ram Air.. T-56 Transmission Removal?
By SteelmanLS1 in forum External EngineReplies: 2Last Post: 08-11-2007, 01:04 PM -
Engine and Transmission Removal ??
By Trouble maker in forum General HelpReplies: 2Last Post: 04-18-2007, 07:27 PM -
Need tips on brake dust removal
By Speedy_Gonzales in forum Showcar and DetailingReplies: 11Last Post: 02-09-2007, 09:55 PM
