Results 1 to 3 of 3
    Member SteelmanLS1's Avatar
    LSX, Oklahoma
    2000 WS6 Trans Am M6
    2000 T/A, Ram Air.. T-56 Transmission Removal?
    Hey guys... Monday and Tuesday I am going up to my buddy's shop and we are going to pull the T-56 out of my 2000 trans am... I am putting in all new hydraulics and a new LS7 clutch kit... My question is, will this be pretty much a normal tranny removal?? What should I have to do to just get it to come out of there? We have a lift and a transmission jack... But what do I need to look out for and make sure I do? Any tips?
    loyall ky
    black, and black
    04 M6
    tranny
    pretty much liek any other tranny removeall just be prepared its a heavy tranny
    LS1 land
    Quote Originally Posted by SteelmanLS1 View Post
    First, make sure you have a lot of extentions for your wrenches! -- And a 26 spline alignment tool.
    I would remove the trans from the bellhousing first, then the bellhousing from the back of the engine. Much easier that way. - Trying to take it off in one piece is a pain in the ass.
    Also, there are 2 alignment pins that are on the bellhousing that go into the trans - they might be stuck in there pretty good. So you might have to pry the trans and bellhousing apart even after all the bolts are out.
    So after i had the trans and bellhousing out i sanded those 2 alignment pins a little to make sure that they slide back into the trans easily. I would test getting the bellhousing and trans back together on the ground to make sure the pinds slide in easily -- its a lot easier than with the heavy ass trans in the air!!
    When i did mine it was a pain trying to get the trans down because the tailshaft of the trans would keep hitting the y-pipe. So you may have to keep going back and forth until you can clear the exhaust. Just be very careful with the trans input shaft.
    Hope this helps. I have the LS7 clutch/ LS2 fly combo and love it!! Feels just like stock, but with a lot more holding power!!
  1. Transmission Removal - Part 1
    By pajeff02 in forum Automatic Transmission
    Last Post: 02-09-2014, 04:47 AM
  2. Transmission Removal Tips
    By rc74racer in forum GTO
    Last Post: 02-06-2012, 07:39 AM
  3. Help: Manual Transmission Removal (hints-etc)
    By TerribleTed in forum Manual Transmission
    Last Post: 02-22-2011, 09:19 AM
  4. 2000 T/A Front Seat Plastic Back Removal
    By Tman in forum General Help
    Last Post: 08-12-2009, 09:35 AM
  5. Engine and Transmission Removal ??
    By Trouble maker in forum General Help
    Last Post: 04-18-2007, 07:27 PM
