    Houston, Texas
    2000 C5 Torch Red
    00 corvette clutch pedal question
    I have a 00 m6 vette with 63k miles. with all this lousy weather I've let the car sit for a few weeks.
    I took it out for a spin and it feels like the clutch is slowly engaging closer and closer to the floor. it only happens at idle and can pump the pedal for feel.
    I started doing the ranger method as the fluid is black as night. changed it so far about 6 times and its still coming up dark.
    I'm going to keep flushing until the fluid is clean, but confused as to why the pedal. would slowly sink down. can be pumped up and will repeat the process.
    No leaks under the car or anywhere I've found. could this be a sign of a falling master? air in the system? or just bad fluid
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Any fluid leaks ?
    Houston, Texas
    2000 C5 Torch Red
    nothing that I can see. fluid level in reservoir is consistent, tho still dark.
    I would be inspecting the master. It is easier to get to and most likely the problem.
    When a slave fails it would be leaking.
    Dark fluid I bet that fluid is toasted, no longer has its viscosity, otherwise it ain't doing jack.
    Flushing out the fluid till it's clear is a good thing to do.
    Houston, Texas
    2000 C5 Torch Red
    That's what the ranger method suggest.
    I know you guys are smarter than I so always good to get a second opinion.
    Will revise once I get fluid clean.
    been waiting for weather to get better as it seems easiest to flush, drive around the block and repeat to get the most bang out of reservoir flushes.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Slave cylinders can go without warning and at no given time. Mine started to go and I noticed my reservoir was 3/4 empty. I filled it back up and the pedal was still mushy. It finally blew when I took my car to the dealer since my shop had no power back when Sandy hit.
    Houston, Texas
    2000 C5 Torch Red
    finally got the fluid clear into my third bottle. so far no recurrences of squishy clutch since cleaned.
    not sure if I'm just treating symptoms, but it was definitely nasty stuff if you don't maintain fluid in these for 60 k+ miles
    North Jersey
    2004 GTO M6
    Keep an eye on your clutch master cylinder and look under the car between the motor/trans to make sure you aren't leaking.
    Houston, Texas
    2000 C5 Torch Red
    Will do. it's clean under at the moment. when I change the oil and under the lift I'll check everything out.
  1. Clutch Pedal Pressure and Smelly Clutch
    By race5050 in forum Manual Transmission
    Last Post: 01-06-2010, 05:37 PM
  2. Light Clutch Pedal (New Clutch)
    By Rhinohuey in forum Manual Transmission
    Last Post: 09-22-2007, 08:51 PM
  3. Light Clutch Pedal (New Clutch)
    Last Post: 09-14-2007, 02:41 PM
  4. Fading Clutch Pedal with new clutch
    By mrbob2 in forum Manual Transmission
    Last Post: 08-17-2007, 05:58 PM
  5. Clutch pedal assembly question
    By M6TA in forum Manual Transmission
    Last Post: 01-29-2006, 04:34 AM
