Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: Rear Bearings
    Member bhunter0830's Avatar
    Apr 2012
    Fishers (Indianapols), IN
    2009 Pontiac G8 GT
    Rear Bearings
    So, I have a rear bearing going back on the passenger rear. Do I need to replace the Axle's with the Bearings and Seals?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I would just pull it and inspect it for any marks or gauging. It will depend on how bad the bearing was worn whether or not the axle got damaged. I would definitely put a new axle seal in though. Most likely the seal will be damaged when you pull the axle and need to be replaced anyway. They are relatively cheap. I would also suggest using RTV on it to ensure it doesn't leak gear lube after install.
    Apr 2012
    2009 Pontiac G8 GT
    Found an axle, bearing and seal package. Might as well just do it all the same time if i'm going to have them out.
    Orlando, FL
    Mean Black
    if the race area of the axle is smooth you don't need to replace the axle. Here is a pic of my bad axle.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    if the race area of the axle is smooth you don't need to replace the axle. Here is a pic of mine bad axle.
    That one is cooked.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I agree. If the axle isn't gouged, then just the bearing and seal should suffice.
    Apr 2012
    2009 Pontiac G8 GT
    I can take the wheel and shake it. I am pretty sure the axle will be toast when I pull them out. But we'll see when it warms back up enough for me not to freeze my ass off in the garage.
    They offer "repair bearings" that ride in a different area of the axle. Never looked into them for our cars, but it is a cheaper option than replacing an axle. Link is to more info: Automotive Cylindrical Axle Repair Bearings
    Timken is a pretty great company. They supply axle bearings to the rail industry. I know one of the Regional Sales Manager's there.
    Agree. If I had to replace a bearing, that is the manufacturer I would try to go with.
    Apr 2012
    2009 Pontiac G8 GT
    Timken is what I have ordered. Does anyone have a 101 on replacing the bearings?
    You have to drop the rear cover and pull the axle c-clip to remove the axle.
    Looks like this:
    If you need a new axle let me know I have 2 spares......plus a carrier, not sure of the gear ratio but it still is serviceable.
    Apr 2012
    2009 Pontiac G8 GT
    Looking for confirmation that the axles are 28 spline. Also, after looking at the RPO codes I have a 2.73 gear... Seriously, anyone have any suggestions on other gears?
    28 spline sounds correct. I assume that is an auto trans with those gears -- 3.73's work great in our car.
    Apr 2012
    2009 Pontiac G8 GT
    Do I need to change the carrier if it go to a 3.73?
    I assume you either have to change the carrier or utilize a ring gear spacer -- preference to the former over the latter.
    Apr 2012
    2009 Pontiac G8 GT
    Back to the bearing. Is there anything special needed to remove the bearing from the axle tube? I think I'll just abuse whats left of the rear end I have and upgrade once I've destroyed it.
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    2.73 gears had a series 2 carrier. You'll need to go up to a series 3 carrier, I believe.
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
  1. Rear wheel bearings
    By ntymd8r in forum General Help
    Last Post: 10-23-2016, 07:47 PM
  2. Question: Rear Bearings and Axle replacement
    By bhunter0830 in forum Firebird / WS6
    Last Post: 10-07-2012, 05:38 PM
  3. How do I know if the bearings are bad on rear end?
    By JayTA98 in forum General Help
    Last Post: 04-30-2010, 06:05 PM
  4. Help: Rear wheel bearings
    By 02fbody35th in forum Drivetrain
    Last Post: 03-02-2009, 05:34 PM
  5. rear bearings...
    By kdog78 in forum Drivetrain
    Last Post: 11-26-2006, 08:15 AM
