Results 1 to 3 of 3
    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    Rear wheel bearings
    has anyone ever changed their rear wheel bearings in their z28, what is involved, how difficult is it
    Arizona
    Axle bearings on a chevrolet 10-12 bolt??? You have to pull the axles which requires removing cover, remove cross pin bolt, remove cross pin, push axles in, remove C-clips, pull out axles. With disc brakes on the rear you will have to also remove the caliper and rotor.
    The seal and bearing will be staring at you which is fixed in the housing. Remove the seal, then bearing. Sometimes the bearings are stubborn and may require a slide hammer with fingers.
    Member One_Bad_TA's Avatar
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    I just pulled mine out to learn how to do it. I used the slide hammer, it was pretty simple and they came out easily. No worries
  1. Rear wheel bearings
    By ntymd8r in forum General Help
    Last Post: 10-23-2016, 07:47 PM
  2. Question: Wheel Bearings
    By psycho_puppies in forum General Help
    Last Post: 11-01-2011, 11:37 AM
  3. Well, not the wheel bearings...
    By Speed_kills_WS6 in forum Drivetrain
    Last Post: 05-29-2009, 04:48 PM
  4. Wheel Bearings?
    By 01ws6er in forum Drivetrain
    Last Post: 11-03-2007, 11:45 AM
  5. Wheel bearings
    By BeaupreFan in forum General Help
    Last Post: 09-27-2007, 01:34 PM
