    Junior Member ntymd8r's Avatar
    Corona, CA
    2001 Chevrolet Camaro Z28
    Rear wheel bearings
    Looking to buy new wheel bearings. From what I've read, I need 2 bearings, 2 seals, rear-end gasket and gear oil to perform the replacement. Can anyone give me their input on brands and part numbers? I was looking at Timken but there are so many sizes and part numbers it gets confusing....help!
    Thanks
    2001 Chevrolet Camaro Z28, M6, Eibach Pro-kit, BMR STB, BMR Adj-PHB, BMR RB's, BMR SB's, BMR Adj-TA, KYB Adj-shocks, K&N, SLP LM, SLP Y-Pipe, SLP Intake, Predator Custom Tuned...
    Treat her well and she'll put a smile on your face every time you get on her!
    Moog and Timken are really good. I used Timken on my 8.8, in fact I just got thru having them pressed on.
    Corona, CA
    Where did you get them from and do you have the part #'s?
    This is for a 10bolt (stock) rear, right?
    https://www.summitracing.com/parts/t...maro/year/2001
    $18.97 @ Summit
    Autozone sells Timken bearings, but make sure you ask specifically for Timken Part # 5707. Otherwise you'll get a National brand, they sell the same bearing and have the same part number. I've been told that Timken has bought out National but haven't been able to confirm it.
    Corona, CA
    Yes.
    I was about to order some stuff from Summit so I'll add that in too. Thanks!
    Just a pointer in case you are not familiar with the rear wheel bearing setup on our cars. The bearings actually ride on the axle shaft and damage to the shaft is not unheard of. Be sure to check the shaft for galling and excessive wear. Is there any reason in particular that you are changing the bearings?
    Orlando, FL
    Mean Black
    Also if you are putting new gear oil dont forget to add the additive to the fluid.
    1998 TA 130k A4, LS6 intake, TunedByFrost, Airlid, AIR and EGR delete, Borla exhaust, front Eibach lowering springs, LS6 valley cover, UMI TQ arm, UMI LCA's, UMI panhard bar, Poly engine mounts, BMR relocation brackets, Blistein HD shocks and struts, Oil catch can, Autotrix window fix.
    Now I have an 2001 F150 5.4L
  1. Question: Wheel Bearings
    By psycho_puppies in forum General Help
    Last Post: 11-01-2011, 11:37 AM
  2. Well, not the wheel bearings...
    By Speed_kills_WS6 in forum Drivetrain
    Last Post: 05-29-2009, 04:48 PM
  3. Help: Rear wheel bearings
    By 02fbody35th in forum Drivetrain
    Last Post: 03-02-2009, 05:34 PM
  4. Wheel Bearings?
    By 01ws6er in forum Drivetrain
    Last Post: 11-03-2007, 11:45 AM
  5. Wheel bearings
    By BeaupreFan in forum General Help
    Last Post: 09-27-2007, 01:34 PM
