Thread: removing axes on a 2002 m6
01-10-2013, 02:11 PM #1
I have a bad axel seal and I am trying to replace it. The thing is that I got to a point where I don't know what to do.I bought an haynes manual so that it would show me how, but In the manual it show a locking bolt on the carrier but on my car it doesn't have it. Any help would be greatly appreciated.
01-10-2013, 04:26 PM #2
If you have the stock rear end still, there's a c-clip which you must remove inside the pumpkin prior to pulling the axle out. It's what retains the axle inside the center-section.
01-10-2013, 07:39 PM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
You should have a center pin held in by a locking bolt. Be careful taking out the locking bolt because they do break and are a PITA to drill out. After you take out the locking bolt you rotate the rear and the center pin should slide out. You then push the axle in and expose the C clip. Use a magnet to remove the C clip and do so on the other side. You will now be able to service the rear axle seals.
01-11-2013, 05:17 AM #4
Thanks fellows, I'll try it today.
01-12-2013, 10:52 AM #5
I have another question. I accidentally rounded the head of the locking bolt, where can I buy another one?
01-12-2013, 11:32 AM #6Member
- Jun 2008
- michigan
black- 1998 trans am
autozone 7.99
01-13-2013, 02:53 PM #7
COB axes prediction that Obamacare will lower deficit
By theorangeguy in forum Political / Debate ForumReplies: 5Last Post: 06-06-2014, 01:11 PM -
Question: Removing the a/c
By sutie in forum Firebird / WS6Replies: 19Last Post: 04-20-2011, 08:51 AM -
Removing LS1?
By KnightmareWS6 in forum General HelpReplies: 17Last Post: 12-05-2009, 10:46 PM -
removing egr and air
By jmatt07 in forum General HelpReplies: 7Last Post: 03-12-2009, 07:18 AM -
Removing the AIR and EGR
By Madcity T/A in forum External EngineReplies: 20Last Post: 08-02-2007, 02:16 PM
