Results 1 to 20 of 20
Thread: Removing the a/c
04-17-2011, 06:35 AM #1ls1 powered seabee
- Mar 2007
- oxnard, ca.
red and black- 1999 Formula/WS6
Removing the a/c
How easy is it to pull out all the a/c components? I never use it and want it gone! (99' firebird)
LS1, SLP lid, SLP MAF, bilstein HP shocks, SLP longtube/tuned headers and loudmouth exhaust, built 4L60E w/ transgo shift kit, true ram air, ported TB, LS6 intake, LS6 PCV w/ catch can, FAST fuel rails, LCRB, sub-frame connectors, wide-band O2.
04-17-2011, 07:00 AM #2
You live in California, & WANT to remove the A/C?!?
That's just wrong, ...
Makes no sense unless it is a track car only.
And even if it is a track car only, you have a long ways to go on mods to reduce et & add mph, before a little weight removal will gain that much.
04-17-2011, 07:03 AM #3ls1 powered seabee
- Mar 2007
- oxnard, ca.
Well I may live in cali, but I never use the a/c, so why not get rid of it and clean up the bay a little.
04-17-2011, 11:09 AM #4
Plan on keeping it forever for yourself?
If not, & might wanna sell it or trade it someday, ..., Don't do it.
Just not a wise decision, IMO.
A/C compressor is at the bottom & you don't see it anyway.
Cleaning up the engine by removing a couple hoses & the dryer is not gonna make that much difference, ..., again In My Opinion.
04-17-2011, 11:26 AM #5ls1 powered seabee
- Mar 2007
- oxnard, ca.
Well thanks for your opinion, but its still going away.
04-17-2011, 11:41 AM #6None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
You'll need to evacuate the refridgerant and oil from the system first. I wouldn't just cut the lines. After that, you'll need to remove all the hoses and equipment. I personally just removed the belt, and left the rest. That way it doesn't produce any drag, but it still can be used again with minimal work. To each his own though.
04-17-2011, 11:44 AM #7ls1 powered seabee
- Mar 2007
- oxnard, ca.
Sweet. I wasn't planning on cutting anything, just a clean removal. Do you know a part number for the new belt? Or is there a tensioner that can be put in place to re use the belt?
04-17-2011, 11:47 AM #8
04-17-2011, 11:50 AM #9None Shall Pass
- Jan 2010
Also, you say you plan on a clean removal. You plan to remove the evap. and condensing coil from the system? It's pretty involved, and I don't know if it can be done with the system still under pressure. You could risk injury - possibly serious, if you try.
04-17-2011, 11:50 AM #10
04-17-2011, 11:52 AM #11
04-17-2011, 05:17 PM #12
My car had the A/C taken out when I bought it. I wish it was still there & I live in Illinois!
04-17-2011, 06:23 PM #13
04-18-2011, 05:27 PM #14
Thanks, but it does get warm without the A/C.
Good luck with taking yours out.
04-18-2011, 06:45 PM #15
does the defrost cycle use the A/C compressor? i'm not sure but i think it might - you wouldn't want to be w/out defrost, whether it freezing temps or fogging windshield..
04-20-2011, 08:42 AM #16
when i took mine out i losened up where the hoses bolted up and just let it slowly leak out after i couldnt hear it i just started unbolting and it was out in 45 minutes i didnt have a cut anything
04-20-2011, 08:45 AM #17
04-20-2011, 08:48 AM #18
im sure it is other wise u gotta take it to a shop and have them take out all the free on. just dont get caught letting it out lol
04-20-2011, 08:49 AM #19ls1 powered seabee
- Mar 2007
- oxnard, ca.
Haha, oh yes, big fine!!!
04-20-2011, 08:51 AM #20
thats what i hear lol
Removing LS1?
By KnightmareWS6 in forum General HelpReplies: 17Last Post: 12-05-2009, 10:46 PM -
removing egr and air
By jmatt07 in forum General HelpReplies: 7Last Post: 03-12-2009, 07:18 AM -
removing the t56
By 69camarokid in forum LT1Replies: 4Last Post: 11-06-2007, 01:35 PM -
Removing the AIR and EGR
By Madcity T/A in forum External EngineReplies: 20Last Post: 08-02-2007, 02:16 PM
