Results 1 to 18 of 18
Thread: Removing LS1?
12-01-2009, 01:51 PM #1Knight Rider
- Jul 2009
- Charleston, SC
2010 Nissan Sentra SR dd- 2001 Pontiac Trans Am WS6
Removing LS1?
It's been a while since I've been on due to crazy amounts of work at school and working. I'm finally getting started on my WS6. The engine has to either be rebuilt or replaced. Either way, what's in there now has to come out. I know that the engine has to come out from the bottom. Has anyone done this on their own in their driveway or garage? I don't have a car lift of any sort but I have an engine crane and jackstands. If anyone can point me to another thread if there is one on how to remove/replace the LS1 on your own, I'd greatly appreceiate it.
12-01-2009, 04:54 PM #2
Most I have seen done have had to jack all 4 corners of the car up and put it on tall custom stands. Usually getting the car's wheels up to 2 feet off the ground and then dropping the cradle with a long reach jack. If you use a cherry picker I think you have to build some sort of cross bar to lift the uni off the engine cradle. search around I know there are write ups on this site about it.
12-01-2009, 05:53 PM #3
There are several step-by-step guides posted on the net -- many with photographs of the entire process. Simply Google "LS1 engine removal" or something similar and you will probably find one that works for you.
12-01-2009, 06:24 PM #4Knight Rider
- Jul 2009
- Charleston, SC
Awesome. Thanks guys. I also got a price quote from a local shop and they said they if I got a replacement motor instead of trying to rebuild the old one, then they could do the swap for 1k. Should I save myself the trouble and time of attempting to do it myself and spend the money? Of course, if I did that, I would lose getting to have the pleasure of knowing that I built that car. Idk. Any suggestions/advice?
12-01-2009, 08:33 PM #5
a thousand dollars is a thousand dollars. if you have the tools and the know how I always say why not. If you take your time and research how to do it right then, they are not going to do any better of a job than you. The differance is they do it more often than you. Hell there is a hot rod video some were of them doing it on a lift and they go through some of the basics.
Go down to the LT1 section there is a thread in there about out the top or out the bottom and someone posted a video of hot rod tv doing one. here i'll get it http://www.bowlingss.com/DownLoads/V...20_removal.avi
here is the thread. there are some pics in here http://www.ls1.com/forums/showthread.php?t=123709
12-01-2009, 08:36 PM #6James Bond
- Aug 2007
- Texas
you dont HAVE to do it from the bottom....but if you have a way to lift it high enough...its easier
12-02-2009, 05:26 AM #7
12-02-2009, 09:40 AM #8Knight Rider
- Jul 2009
- Charleston, SC
Well, the engine isnt coming out for any upgrade reasons. At least, it wasnt going to. But it has to so I'm going to upgrade it while it is out. I bought the car as a project for 2k, which was a crazy steal. See, I live in Charleston, SC, which is on the coastline. And Downtown Charleston is on a Peninsula and the roads flood a lot when it rains. So the previous owner was driving it in Downtown one day and tried to go through one of the "puddles" which can get up to about 3 feet deep. Not knowing anything about cars obviously, she kept on driving. The water came accross the hood and being that the WS6 is Ram-Air, the water proceeded to go straight into the engine and water-logged it. So now the engine is toast and has to be completely rebuilt or replaced.
Thanks for the video and link. Hopefully that will help alot. I do have the know how so I think I'll just save the 1k and put that towards an SLP exhaust and upgraded ram air intake. I've swapped the engine out on my '95 Mitsubishi Eclipse daily driver and multiple 2nd gen Trans Ams so I should be good to go.
12-02-2009, 10:25 AM #9
12-02-2009, 12:09 PM #10LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
everytime i've seen people try to pull it from the top, they end up needing a pretty good amount of body work and paint afterwards (but i also may know a bunch of careless idiots). i would definitely suggest pulling it from the bottom ... unless you're extremely careful and take your time
12-02-2009, 01:14 PM #11
Not only that, but if you remove it from the bottom, you can leave the transmission attached, saving the trouble of trying to disconnect the two while they are still in the car. Which as many know can be troublesome. Its really just a matter of disconnecting the appropriate harnesses and hoses and lowering the entire powertrain as one unit.
12-02-2009, 01:16 PM #12
12-03-2009, 12:43 PM #13Knight Rider
- Jul 2009
- Charleston, SC
I didnt even think I was possible to actually get it out the top. I was already planning on doing it from the bottom. I just wasnt sure of the best approach for it.
12-03-2009, 12:50 PM #14
12-03-2009, 12:56 PM #15
Taking it out the bottom will also give you room to clean up the engine bay and check out all the other parts on the front end to see if they need some attention. Also gives you time to plan out how you want to take the motor apart and tag and bag it.
12-03-2009, 06:06 PM #16Impounded
- Apr 2006
- park bench
- gmcheviac
12-05-2009, 10:45 PM #17Knight Rider
- Jul 2009
- Charleston, SC
I think all the rest of the parts in the engine bay should be fine. I havent had a chance to really check anything because the battery wont hold a charge and needs to be replaced. I did get the radio to come on briefly and I must say, for a stock stereo, its got some kick to it.
And I was also thinking of having it painted while I worked on the engine. I'm not sure about it as far as money is concerned though. But if I can, I was thinking of going with a two tone sort of deal. I really like how the Corvette ZR1 looks with the color on the bottom half of the car and the black on the pillars and the roof. I was thinking of doing that kind of paint scheme with a blue close to the one that is on the ZR1. The Nocturne Blue on the '79 my dad has is somewhat similar. I think either one of those would look good on there. That would change it up a bit and make it stand out from the usual black, white, red, and pewter WS6s. I'll post a pic of the ZR1 now so ya'll can see the color that I'm referring to. I cant find a recent pic of the '79 T/A. I'll have to look on my other computer.
12-05-2009, 10:46 PM #18Knight Rider
- Jul 2009
- Charleston, SC
Question: Removing the a/c
By sutie in forum Firebird / WS6Replies: 19Last Post: 04-20-2011, 08:51 AM -
removing egr and air
By jmatt07 in forum General HelpReplies: 7Last Post: 03-12-2009, 07:18 AM -
removing the t56
By 69camarokid in forum LT1Replies: 4Last Post: 11-06-2007, 01:35 PM -
Removing the AIR and EGR
By Madcity T/A in forum External EngineReplies: 20Last Post: 08-02-2007, 02:16 PM
