Results 1 to 18 of 18
    Jun 2009
    pewter
    95
    droppin motor out bottom
    getting ready for the winter project anyone have links on how to drop motor out bottom on the f bodysince im goona do clutch and everything at once
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    I just don't understand all the extra work of dropping it out the bottom. Why is it people want to take it out the bottom?
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    It's easier then going out from the top since our motors are so far back.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    You all need to check this out then. http://www.tpis.com/index.php?module...y=Happy+Hooker
    Also here is a tech thread http://ls1tech.com/forums/lt1-lt4-mo...ift-plate.html
    Stop waisting so much time.
    Oct 2001
    Colorado
    95 Z28
    Quote Originally Posted by JaycenK View Post
    Stop wasting so much time?!?!? ahahahahahahaha
    Using a lift, I've had an entire engine/tranny out of an F body (from below) in less than an hour.
    BTW that is how techs at dealerships do it (out the bottom). When you're flat rate you find the quickest way to do things= you make more money.
    Jun 2009
    pewter
    95
    i want to drop from bottom im guessing it would be easier i want to flush out brake fluid do the suspension.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    Bottom is easier..... Top is for douchebags.
    Ive done it in 2hrs with a floor jack and a cherry picker.
    Wisconsin
    2001 Camaro SS M6
    It took us 2hrs to take it out the top with the hood on. Maybe you guys just need better mechanics
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    I as in Me alone.... and I got the tranny too.
    Coral Springs, Fl
    Sunset Orange Metalic
    http://www.bowlingss.com/DownLoads/V...20_removal.avi
    They leave out some parts but it may help some
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Weel I guess this is a debate that will roam on for ever as there are fans of top and bottom. lol
    Member RARON455's Avatar
    fort worth texas
    98 Ram air T/A Ls1/T-56
    I pulled mine from the top, not that bad.
    Jun 2009
    pewter
    95
    i want the 6 speed out too
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Quote Originally Posted by 6801 View Post
    Nuff Said then.
    I always drop out the bottom but having said that it makes it easier to do my front suspension (mostly rod ends replacement) maintenance at the same time.
    Junior Member siguy's Avatar
    Nov 2009
    staten island , ny
    95 ta
    gezzzzz drop out of the bottom it is so much easyer...
    Also i makes life so much easyer when you want to ter down the engine .. i mean you can drop 100% of the motor tranny and wiring harness all in one shot... same as when you put the motor back in
    Pittsburgh
    2008 Hummer H3
    Toodah!!
    Ed Wright, local tuner and known throughout the country pretty well, always takes his out the bottom. He has it down to such a science, he can have it out the bottom in 40 minutes. Most people with experience doing it both ways will tell ya, out the bottom is faster/easier.
  1. Question: droppin the TA
    By Brad(WS/Z0.6) in forum Firebird / WS6
    Last Post: 03-26-2009, 01:31 PM
  2. How to drop motor from bottom with a lift?
    By mikeaford in forum Internal Engine
    Last Post: 02-19-2007, 12:08 PM
