Results 1 to 13 of 13
Thread: droppin the TA
03-26-2009, 10:32 AM #1
droppin the TA
i want to drop my car an inch or two...i have been told that i can simply cut half a coil out of each of my springs and just put them back in...is there anyone who can verify this or has any suggestions??? Thanks
03-26-2009, 10:48 AM #2
dont cut the springs ...springs are made the length they are for a reason...ride comfort and drivability will suffer if you cut them. appearance wise it will look good but functionality will suffer.
03-26-2009, 11:10 AM #3
invest in the Eibach LT1 prokit. it's what i have on my car. perfect height after being dropped. the front springs have a higher spring rate so that the front is not slammed down and you have issues going over speed bumps...
03-26-2009, 11:19 AM #4
03-26-2009, 11:52 AM #5
the SS has a nice slight forward rake, that's what i like about it...
now, on my '95 TA project car, im going LS1 prokit on it to really slam the car down low...
03-26-2009, 12:06 PM #6
03-26-2009, 12:23 PM #7
heres a question related but not on topic, is puttin in your own lowering springs a good idea? i've heard if you haven't done it there can be complications like losin a spring shootin through the fender, but is this something that would be easier paying someone to do?
03-26-2009, 12:25 PM #8
thanks, best of luck with lowering your TA as well...
03-26-2009, 12:27 PM #9
i have the eibach pro kit on my TA and i love it how it looks and rides. i also threw in sway bars to get rid of the roll. but yeah, its a nice little kit
1999 Trans-Am
Lid, Flowmaster cat-back, Eibach 1.25 Pro Kit, front and rear Eibach Sway bars, LS7 clutch
03-26-2009, 12:30 PM #10
i did the rears because they are easy and straight forward to do. the fronts are harder because it takes a #50 torx head to loosen and remove the bolts holding them in the strut mounts. you will need a spring compressor to compress the springs for the front (not needed in the rear), and that's where if you don't do it right, the likely hood of a spring flying off in some direction is a possibility...
i took mine to a local performance shop for the fronts and glad i did. the rubber isolator on the passenger side was rotted away, which they replaced. you might run into that, or you could strip the nut to the spring. basically a whole host of issues could arise with doing the fronts (or no problems at all). they had both sides installed in about an hour. far quicker than i know i could have done so by myself and charged my only 1hr of labor to do so...
03-26-2009, 12:34 PM #11
thats what i was kinda worried about, but thats a great idea. i'll probably do what you did and do the rear and take it to the shop in town for the fronts. thanks man, thats exactly what i needed. my car looks like an suv, i need to drop it bad too. oh and brad good idea, drop it. it'll look amazing
03-26-2009, 12:37 PM #12
03-26-2009, 01:31 PM #13
i got my setup through my old job that i was with at the time and then me and a buddy i worked with lowered it ourselves at work on a day that we were closed. the rears took maybe 10 minutes to do while the fronts took a couple hours. save the money and do the rears yourself. its not too hard
droppin motor out bottom
By 6801 in forum LT1Replies: 17Last Post: 11-15-2009, 05:45 PM -
Chevy Big Block Distributor Swap - Droppin' Spark
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 06-04-2009, 01:20 AM
