Thread: fuses keep blowing???
04-05-2006, 08:40 AM #1
OK, Not sure whats going on but when ever I turn my lights on a fuse blows. Usually the tail lights fuse, sometimes a different one. It has all the correct fuses in each slot. Just started happening yesterday. I've replaced the fuses several times now and as soon as I turn the headlights switch one turn the fuse blows and the fog lights and parking lights cut off completely. The headlights work fine. The parking lights work fine if the headlights are off. Even when I unlock the car with the button the fuse blows. Anybody have any idea what may be wrong??
04-05-2006, 03:10 PM #2
There is something shorting out somewhere-there was another thread in here somewhere that the guys body control module was filling up with rain water or something-maybe you have a similar issue. If you are not good with electrical stuff and don't see something obvious you'll need the help of a pro to trace it down.
04-05-2006, 03:45 PM #3
Mayb have a bare wire rubing against somthing somewhere. Definatly a short.
04-06-2006, 06:04 AM #4pontiac_godGuestPull out the bad fuse and if you have an ohmmeter, then measure the side that is not at 12V (in the fuse holder) to ground. If you have continuity then you have a short to ground - which I'm sure is what is going on. Unplug connectors.....etc.... on that circuit until you have infinit continuity to ground from that fuse point and you will have narrowed it down.
Originally Posted by blackTA6585
04-06-2006, 08:27 AM #5
nice method-and good explanation-thanks!
Blowing Air Conditioning Fuses
By ls1camino in forum General HelpReplies: 6Last Post: 07-29-2011, 05:15 PM -
blowing fuses car wont start need help
By white02Z28 in forum General HelpReplies: 4Last Post: 01-16-2008, 10:35 AM -
Blowing Fuses!
By Ryans99LS1 in forum General HelpReplies: 3Last Post: 12-07-2007, 08:16 PM -
Blowing fuses
By 2000 SS Beast in forum General HelpReplies: 7Last Post: 10-10-2007, 09:34 PM -
why do i keep blowing fuses?
By sgt0704 in forum Stereo and ElectronicsReplies: 4Last Post: 07-29-2006, 08:35 PM
