Thread: Blowing Air Conditioning Fuses
07-25-2011, 04:42 AM #1Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
This is on my brother's 2000 Grand Am 3.4L.
When he bought the car, the AC worked fine, two weeks ago it went out for no reason. I thought it was a fuse, and I replaced 3 different HVAC fuses (one on the passenger side interior and 2 under the hood). Nothing changed, so I figured it was the blower motor. While pulling appart the interior to replace the blower motor, I noticed ANOTHER fuse panel, this time on the passenger side interior. I pulled the cover off and found another HVAC fuse (20A). I pulled it and found it was blown
So, I replaced it with another 20A, and as soon as my brother turned the ignition to ON (didn't start the car) the replacement fuse blew. I didn't have another 20A, so I replaced it with a 30A. Turned that ignition to ON and that one popped too. I'm lost as to why this is happening. Stock is 20A, but it's not even lasting a second upon startup.
What should I check next?
07-25-2011, 07:37 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Sounds like a short. I'd see if you could trace the wiring from the fuse to wherever it goes. Might be a wire that is shorting against the chassis or something.
07-25-2011, 01:29 PM #3Spaz is My Mentor
did you jump start the vehicle recently? Sometimes the surge can fry the wire harness if the cables are not grounded.
Looking for electrical shorts is a nightmare. Good luck.
07-25-2011, 02:37 PM #4
07-25-2011, 05:48 PM #5Senior Member
- Apr 2008
- Madison, WI
Check the blower motor resistor. Super common failure point on that car. Usually just causes the low blower speeds to not work, but could be shorted and blowing the fuse. Next most likely thing is the blower motor itself.
Here's a video how to for blower resistor replacement. Its a little bit of a pain in the butt.
07-29-2011, 04:52 PM #6
07-29-2011, 05:15 PM #7
unplug everrything, turn key on, start plugging stuff back in, the thing when plugged in that blows fuse is it in most cases.
Air conditioning not blowing though the vents
By qwik219d9 in forum General HelpReplies: 16Last Post: 04-13-2011, 03:56 AM -
Blowing Fuses!
By Ryans99LS1 in forum General HelpReplies: 3Last Post: 12-07-2007, 08:16 PM -
Blowing fuses
By 2000 SS Beast in forum General HelpReplies: 7Last Post: 10-10-2007, 09:34 PM -
why do i keep blowing fuses?
By sgt0704 in forum Stereo and ElectronicsReplies: 4Last Post: 07-29-2006, 08:35 PM -
fuses keep blowing???
By blackTA6585 in forum General HelpReplies: 4Last Post: 04-06-2006, 08:27 AM
