Thread: Blowing Fuses!
    Parma Heights, Ohio
    SOM
    99 Trans Am
    Blowing Fuses!
    Well i pulled 3 codes. One was for my IAT getting "Excessive voltage" and the other 2 said my AIR solenoid and relay were bad. I checked the AIR fuse and it was blown. I replaced it, and it keeps blowing. Didnt get to the IAT sensor yet. Could the high voltage be blowing that fuse? what should i do?
    99 TA-T56 swapped, Lid, TB Bypass, LS6 Intake, !EGR, !AIR, Custom Cam, Mids, O/R-Y, 3:73s, Cutout, Flowmaster.
    A4 numbers w/ mids only 320RWHP 333RWTQ
    Cam numbers and track times soon.
    98 NBM Hardtop Formula- Bone stock, A4, 187,000 miles
    13.8@ 103 2.1 60' 1357 DA
    Senior Member
    Jacksonville, FL
    The IAT sensor and secondary air are separate, don't see how P0113 would be related to the air pump circuits blowing that fuse. If you go to gearchatter.com you can look up the codes/diagnostics for your year, looked at P0113 and it even shows the wiring diagram. I'd replace the sensor if it's bad and then look at the secondary air codes.
    Parma Heights, Ohio
    SOM
    99 Trans Am
    Yeah thats how i read the codes, i was on gearchatter. I just dont get why the system keeps blowing the fuse. I need to pass emissions but im most likely just going to back to my tuner and have him tune out the AIR and EGR system.
    Feb 2006
    2002 WS6
    chances are the air pump has a shorted motor.
  1. Blowing Air Conditioning Fuses
    By ls1camino in forum General Help
    Last Post: 07-29-2011, 05:15 PM
  2. blowing fuses car wont start need help
    By white02Z28 in forum General Help
    Last Post: 01-16-2008, 10:35 AM
  3. Blowing fuses
    By 2000 SS Beast in forum General Help
    Last Post: 10-10-2007, 09:34 PM
  4. why do i keep blowing fuses?
    By sgt0704 in forum Stereo and Electronics
    Last Post: 07-29-2006, 08:35 PM
  5. fuses keep blowing???
    By blackTA6585 in forum General Help
    Last Post: 04-06-2006, 08:27 AM
