    Junior Member WHITE TA's Avatar
    Feb 2012
    Aloha oregon
    2001 Trans Am
    is there anyway to get an ls1 to not tick
    Is there anyway to get an ls1 to not tick cold?
    Leave it off.....
    But seriously - hate to say it but it's a normal thing with a LS1. I read others have experimented with different oil weights but to be honest I'm not sure how that would help.
    I think a roller rocker's would help. Not 100% sure here. Others that have done this should chip in.
    Feb 2012
    Aloha oregon
    2001 Trans Am
    It just sounds bad if your showing off your car and fire it up and it ticks. Already tried heavier wieght oil
    Junior Member danjo11's Avatar
    May 2011
    Kentucky
    Victory Red
    2000 SS
    Its the nature of the beast. The aluminum block heats up quicker than the iron / metal internals and creats room for piston slap. There is no way to cure it. LS1's have loose variances. Its GM's loose = fast philosophy. Nothing to be concerned about, but I agree it is annoying.
    Quote Originally Posted by WHITE TA View Post
    It just sounds bad if your showing off your car and fire it up and it ticks. Already tried heavier weight oil
    Those ppl that know nothing about LS motors will complain but if you explain to them with the post below they should understand why if they are gear heads.
    Quote Originally Posted by danjo11 View Post
    Its the nature of the beast. The aluminum block heats up quicker than the iron / metal internals and creates room for piston slap. There is no way to cure it. LS1's have loose variances. Its GM's loose = fast philosophy. Nothing to be concerned about, but I agree it is annoying.
    also a good set of LT headers covers the noise for me
    Senior Member kenro23's Avatar
    Feb 2011
    Houston
    '00 SS
    Yuuup!!!!
    Suspension: Lower control arms (Spohn), Drive shaft safety loop, Torque arm (Edlebrock), Strut tower brace, Panhard Bar (BMR)
    Under the Hood: Smooth bellows, Lid, Catch can, LT Headers, ORY, AIR/EGR delete, Poly engine/transmission mounts,
    Exterior: Painted brake calipers (Red), Halo “Spyder” Headlights w/matching parking/turn signals (Black)
    Feb 2012
    Aloha oregon
    2001 Trans Am
    Thanks for the info
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Talking
    Do not turn the engine on!!!
    SteveC
  1. Tick-a-tick-a-tick-a-tick-a...Rear end when cornering
    By bhunter0830 in forum Suspension and Handling
    Last Post: 04-06-2012, 04:37 AM
  2. getting rid of the ls1 tick
    By V8MUSCLE in forum Internal Engine
    Last Post: 11-28-2009, 10:53 AM
  3. HELP I need help with tick
    By FBracing1222 in forum Internal Engine
    Last Post: 11-11-2009, 03:42 AM
  4. Tick, Tick, Ticking sound.....
    By clg82 in forum Firebird / WS6
    Last Post: 05-17-2007, 01:20 PM
  5. Tick-tick noise: LS1 vs. Northstar
    By Jack M in forum Internal Engine
    Last Post: 07-07-2006, 12:14 PM
