Thread: HELP I need help with tick
11-02-2009, 11:47 AM #1
I just swaped my cam and the rockers keep on loosening. it makes it tick really bad. What do I do?
11-02-2009, 05:46 PM #2
What rocker do you have ? Stock ?
11-02-2009, 05:53 PM #3
If they are, they're not adjustable, you tighten them all the way down...
11-02-2009, 07:09 PM #4
When installing, what are you torquing them to? Also, are you spinning the motor over a few times and checking the torque again? Blue Locitite can also be used if its a persistent problem. Installing them is easy, as you probably know. But here's a diagram showing the method used in the books. I for one have never used this, Just tighten them down to spec, turn engine over a few times and check torque again.
11-06-2009, 10:32 AM #5Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
22 ft.lb and high temp loctite and no problem so far......
11-11-2009, 02:42 AM #6Junior Member
- Kentucky
S O M- 2002 Camaro SS
Did you check preload on the lifters? The new cam you installed undoubtedly has a smaller base circle and you probably need longer push rods.
That said, cammed LSx engines generally have more valvetrain noise.
is there anyway to get an ls1 to not tick
By WHITE TA in forum General HelpReplies: 7Last Post: 05-09-2012, 04:02 AM -
Tick-a-tick-a-tick-a-tick-a...Rear end when cornering
By bhunter0830 in forum Suspension and HandlingReplies: 8Last Post: 04-06-2012, 03:37 AM -
getting rid of the ls1 tick
By V8MUSCLE in forum Internal EngineReplies: 13Last Post: 11-28-2009, 09:53 AM -
Tick, Tick, Ticking sound.....
By clg82 in forum Firebird / WS6Replies: 63Last Post: 05-17-2007, 12:20 PM -
Tick-tick noise: LS1 vs. Northstar
By Jack M in forum Internal EngineReplies: 1Last Post: 07-07-2006, 11:14 AM
