Results 1 to 14 of 14
    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    getting rid of the ls1 tick
    when i start my car on cold/colder than 100 degree days i have a godawfull tick till the car warms up. what is the way to go about getting rid of this, cam/lifter swap?
    i have heard you cant replace just 1 lifter as the wear patterns would wear the new lifter/cam out very fast. any truth in this?
    i do know the car has been above redline. when i first got it, literally, coming home from the dealership, got on it, then my noob ass missed 3rd. WHAAAAAAAAA.
    ive had it for a little over 2 years now and it sounds like it is getting worse in the mornings, maybe its just because its getting colder so its more noticeable, but it sounds like its knocking like a son of a bitch for the first 3 minutes.
    I have been thinking about doing a cam swap, the 228r from texasspeed. i have done a cam swap before, but i was helping somebody else, so im not 100% sure what all i will need.
    i have 140k miles.
    NC
    1998Z28
    You could have some bent pushrods if when you missed a gear causing your tick.
    LS1s have roller cams and can be swapped out and the old lifters reused without worrying about a preworn pattern. What you said is true about non-roller/flat tappet cams.
    http://www.installuniversity.com/ins...sity/index.htm is a good site for DIY.
    Coral Springs, Fl
    Sunset Orange Metalic
    may have a bent pushrods but if its just a tick its probably just lifters
    no real cure for lifter tick
    You could swap the lifters but you still may end up with the same noise
    Coral Springs, Fl
    Quote Originally Posted by PFM View Post
    beat me to it
    402 Guru 402 Guru's Avatar
    Jan 2008
    las vegas
    02 Trans Am T-tops M6
    +1 ive seen many people that miss the legendary 2-3 shift then bend a push rod just get a new cam and lifters and pushrods if you go chrome-molly (comp cams) then you can spray the hell out of em or just no adders and have security of a pushrod deflecting and cracking your block the faster you change it the longer your engine will live just in my experience . or u can save up and stroke your block and resleeve it to well over 400+ cubic incles or 383 is the max with out resleeving it either way Mod-Fever is a awesome thing and you will never regret putting money into your Engine ending everytime you drop the hammer you will see what i mean
    Jan 2008
    las vegas
    if the ticking gets louder when your driving then its your pushrod Now if it ticks when your car is cold its the common lifter tap that most ls1's( stock )have a nice set of chrome molly lifters from comp cams will get that to go away
    Aug 2009
    NC
    midnight blue
    2000 trans am
    I think he might be talking about the piston chatter, cause I know that when our cars are crunk up at cold the pistons will have alot of play in them until the car is warmed up. So I have read from multiple sites, and he is talking about it going away after it warms up so it might be an over reaction and its just that normal old ls1 cold start sound that every (stock)ls1 has.
    NC
    SOM
    1998 T.A.
    Quote Originally Posted by bluehawk2000 View Post
    ^^^^yep. If it goes away it is piston slap. VERY common in these motors. My 5.3 has it the LS1 does not. Don't sweat it. 196K and going strong on my 5.3
    Bent PR will not go away when warm.
    Usually a collapsed lifter gets WORSE as the engine heats up and oil thins out....
    Aug 2009
    NC
    midnight blue
    2000 trans am
    Quote Originally Posted by SOMbitch View Post
    And if I am also correct that happens with forged motors to you will hear a piston slap till the motor warms up and the pistons can expand back to conform to the walls of the cylinders. It is just like alot of other things when its hot or cold metal shrinks and expands. My trans am does it here for about 5 mins or so of running during the summer that is until its warm and then its gone after its warmed up never really worried about it.
    NC
    SOM
    1998 T.A.
    ^^^^^^ Yep......not uncommon....^^^^^^^
    Member BlackSS1's Avatar
    Lexington, NC
    2001 Camaro SS Vert
    Quote Originally Posted by V8MUSCLE View Post
    i have 140k miles.
    If you do the cam swap, check out www.ls1howto.com for step by step instructions. I was new to internal engine work, and this guide led me right through the install including what to get prior. The 228R is a great street cam, I have it and love it.
    Aug 2009
    NC
    midnight blue
    2000 trans am
    Quote Originally Posted by BlackSS1 View Post
    whats the specs on your cam and have you dyno'd?
    Lexington, NC
    2001 Camaro SS Vert
    Here is the thread on the project, dyno chart, video of idle, etc:
    http://www.ls1.com/forums/showthread.php?t=116636
    It made 380 RWHP and 370 RWTQ with stock heads, headers, catback, lid, tune. Specs are 228/228 .588/.588 on a 113LSA.
    Aug 2009
    NC
    midnight blue
    2000 trans am
    Sweet man I appreciate it
  1. is there anyway to get an ls1 to not tick
    By WHITE TA in forum General Help
    Last Post: 05-09-2012, 04:02 AM
  2. Tick-a-tick-a-tick-a-tick-a...Rear end when cornering
    By bhunter0830 in forum Suspension and Handling
    Last Post: 04-06-2012, 03:37 AM
  3. HELP I need help with tick
    By FBracing1222 in forum Internal Engine
    Last Post: 11-11-2009, 02:42 AM
  4. Tick, Tick, Ticking sound.....
    By clg82 in forum Firebird / WS6
    Last Post: 05-17-2007, 12:20 PM
  5. Tick-tick noise: LS1 vs. Northstar
    By Jack M in forum Internal Engine
    Last Post: 07-07-2006, 11:14 AM
